Flex joints (not flexpipe)
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone ever use one of these?
Looks like it'd be a killer deal to help a home-fab exhaust. I wonder though, what it does for performance..
http://www.pacesetterexhaust.com/perf_exhaust.htm
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
i dont think they would be long enough for any substantial bend, but they would be very good if you wanted to mount your exhaust solid
Car: 1991 z28
Engine: l98
My friend has one on his 71 chevelle, Mufflex put it in for the crossover on the h-pipe. I guess it helps reduce stress from twisting. Kinda has to in his car, a 500 hp 427 can do a lil teisting, even on a full frame.
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
Originally posted by biff85ta
Those are for FWD applications to allow the motor to move back and forth without messing up the exhaust.
I don't see why you would need it in the first place. The exhaust is hung from rubber hangers so you have all the flex you need already. It's not like the pipes are welded directly to the chassi.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Flex pipe
Flex Pipe Install
There's the link to my installation of a flex pipe.. Its been on since april and is working great.. I haven't had any exhaust leaks since I put it on (i was having to replace header and collector gaskets semi-frequently before)...
sjorgens
Oct 1, 2015 07:54 PM
