which hedman header
Old Oct 9, 2003 | 08:39 AM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
which hedman header
i was looking at the hedmans and was wondering which one's to go with on my 305 tpi. footnote 5 says with A.I.R. Is this the oxygen sensor or the air injection system to the convertor or the smog system? my car had the cat taken off. i want to take off the smog pump and wanted to know if it would cause computer problems or cause it to run too rich or too lean? help is useful.
Old Oct 10, 2003 | 02:52 AM
biff85ta's Avatar
Car: 04 Vette
Removing the smog pump will not cause any problem with thw fuel mixture what so ever.
Old Oct 10, 2003 | 08:02 AM
Car: 85 Z28
Engine: 305 LB9 TPI
hedman's
would it cause an error code to show when the sensors are disconnected?
Old Oct 10, 2003 | 11:31 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
no A.I.R is the smog pump and tubing that pumps air into the current exhaust manifolds, you can remove this without trouble and computer problems, but you must retain the o2 sensor.
Old Oct 27, 2003 | 09:36 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I took off the pump and lines on mine and plugged my headers with the air system. I kept the O2 sensor of course but I noticed a difference in the smell of the exhaust. Smells like it is running richer but it isn't really. I have a air/fuel mix. gauge and I didn't notice a difference in it. I personally like the smell better. Just reminds me of old school.
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
