POR 15 Header Coating
Old Nov 10, 2003 | 04:57 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Has anyone used POR 15 Aluminum finish exhaust coating on headers? Results?
Old Nov 11, 2003 | 01:51 PM
davehamilton's Avatar
Hello, Who makes thes coating? We use a Silver gray aluminized basecoat and I'm wondering how what you are asking about compares. What are the exact ingredients?
Thanks JIMI @ ACS
Old Nov 11, 2003 | 03:18 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I have. It turned out pretty good, except for the headers weren't in great shape to begin with...lots of rust and scabs on them beforehand and I only wirebrushed the loose stuff off. They're 8-year old Hedmans, and I wasn't gonna spend $80 to have them sandblasted like what should have been done. As long as the prep work is good, the results will be good.
This is how they looked in my Formula just after being installed.
I used POR-15 gloss black on the inner fenderwells and lower firewall.
Pete
Old Nov 12, 2003 | 01:01 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Haven't ever used it, but if it's as good as their other coatings you won't have a problem. Have you also looked at CeramaKrome or Black Satin by Tech Coatings (I think that's the company name)?
Old Nov 12, 2003 | 07:55 PM
OMINOUS_87's Avatar
I have.
Some things to follow to get a good lasting finish.
1. Put them on a known good motor with proper timing, not a new motor where the timing could be jacked and you will super heat them from the get go.
2. After mounting them start the motor and let it idle for only about a minute, then shut it down and allow them to fully cool.
3. Of course follow the directions on the can properly!!!
The finish will be real nice and should last a very long time.
Old Nov 12, 2003 | 08:13 PM
bigals87z28's Avatar
Car: Check The Sig
id like to see heat test on all these coatings.
Old Nov 12, 2003 | 10:30 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Pete
Wow, your headers look pretty good. When I go to swap my heads this spring, I might take off my headers and sand blast them and try some of that stuff. How much of it would I need to do shorty headers???
Old Nov 12, 2003 | 10:47 PM
OMINOUS_87's Avatar
These have been replaced with Hooker 2210 coated LTs, so I have no pics of em in the car, they were only used for like 100 miles. But thats what the POR-20 looked like.
Old Nov 13, 2003 | 01:05 AM
Thanks! The picture isn't great quality, and they'd only seen maybe 20 minutes of running time by then. If you can take them down to bare metal, your results will be better and probably last longer.
As for how much to get - I bought a pint, and di two coats on the headers, two coats on the y-pipe, and two coats on the complete cat-back, and still have about 1/3 of that pint left.
Pete
Old Nov 13, 2003 | 07:58 AM
OMINOUS_87's Avatar
I blasted mine and then acid etched them as well with the POR products Metal Ready. Resto-Motive is the sheet!
A pint goes forever, I think thats what I got, the smallest can.
Old Nov 13, 2003 | 06:14 PM
bes217's Avatar
What is that box that is on that engine, on top of the runners.
Old Nov 13, 2003 | 06:47 PM
Car: Check The Sig
That is called a super ram. Its a step up from TPI. Its the only non-LTR set that retains EGR function.
Old Feb 10, 2005 | 03:32 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Just wanted to bring this back ...... from the dead. I wanted to see if there are any new info/opinions. I plan to go this route also, on a set of TES Headers. I may do my HOOKER CAT-BACK also, just cuz i live on an island in the middle of the PACIFIC. Thanks for the NEW news,
SHAWN
Old Feb 20, 2005 | 10:33 PM
TTT
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
