New engine, the spintech just got louder
Car: '82 Z28
After a little fright last night thinking I had some major problems, everything is working great with the new engine. Here's just a quicky video I did a few min ago to show off how the exhaust sounds. It's much better in person but you'll get the idea
Here's the video, 0.5 MB Only reved it to about 3,000 and was idling at about 750 rpm.
Here's the video, 0.5 MB Only reved it to about 3,000 and was idling at about 750 rpm. Thread Starter
Car: '82 Z28
Originally posted by Jgolden314
sounds good........what engine did ya put in?
Speed Demon 750 DP
Torker II (being replaced by a Victor Jr. intake soon as I can)
CompCams Pro Magnum RR's
CompCams 294S
* Duration at .050 in. cam lift: 248 intake/248 exhaust
* Gross valve lift: .525 in. intake/.525 in. exhaust
* Lobe separation: 110 degrees
CompCams Solid lifters
AFR 195 aluminum heads 68cc
ARP Head studs
Wiseco forged pistons, flat top (10:1)
Eagle ESP (H-beam) 6" rods
Stock GM steel crank with a bit of extra machine work done to it
ARP Main studs
6" 1/4 Fluidampr
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like a really nice motor....what HP are you expecting out of it?
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Sounds like a dragster
Glad to hear everythings ok !
Car: '82 Z28
Here's another quick video. Decided to do the old camera on the ground video
Just got back from driving around and stopped on a side road to check things. The #2 spark plug wire is arching on the header so new wires, booties and brackets are in order.
What do I expect out of it? Eventually getting it up to 475 - 500 hp, I'm guessing it's right close to 400 now. Times I'd like to get, mid to low 12's N/A and somewhere in the 11's on the bottle. Still need to change the intake, exhaust system, gears and do chassis and suspension work. Still got plenty of work to do and more money to throw at it lol.
Just got back from driving around and stopped on a side road to check things. The #2 spark plug wire is arching on the header so new wires, booties and brackets are in order.What do I expect out of it? Eventually getting it up to 475 - 500 hp, I'm guessing it's right close to 400 now. Times I'd like to get, mid to low 12's N/A and somewhere in the 11's on the bottle. Still need to change the intake, exhaust system, gears and do chassis and suspension work. Still got plenty of work to do and more money to throw at it lol.
Car: 1989 IROC-Z
Transmission: 700R-4
Sound great man.....now when you say you are gonna change that exhaust, that scares me a little since it sounds sooo good. You will stay with spintech though right? If I recall right, you have their Pro shoot out.
Car: '82 Z28
Yes, I'll be adding another 3" pro shootout and long tube headers for dual exhaust. Should sound even better after that's done
It'll be a while before I can do it though, have to get some other things sorted first.
It'll be a while before I can do it though, have to get some other things sorted first. Senior Member
Car: 1989 IROC-Z
what size do you have on there now? You happy with the single in/out? I think that's exactly what I'll be running in back of the hooker 2055s. I just need to get the hard part of putting the new engine in out of the way.
Car: 1989 IROC-Z
Oh, and can you maybe post a picture of your muffler you have now....I just want to see how you have the single in/out mounted and how you have the turn-down......I know.....
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
More videos please!
I love the way that Spintech sounds. If cops weren't so bad around here, thats probably the setup I would run.
Car: '82 Z28
I have a 3" single right now from the y-pipe back. The exhaust pipe is pretty well hidden if you're looking from behind, kinda goes up then turns down a bit at the back. Wish I had the video camera last week cause a friend of mine and I both did a couple of nice burnouts at his shop lol. I'll try for a better video this week
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
That's just the opposite of what happened to me. The 383 is actually quieter than the 350 was with the same cam/heads/exhaust.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Does your car know you changed the engine?!
Really though, that's wierd. Did it get more of a rumble even though it didn't get louder??
Car: 1989 IROC-Z
Is that all mandrel bend 3" pipe? What is the size of the muffler itself....looks a little larger than my dad's pro street (street muffler, but I thought the pro shoot out and pro street came in the same size). Will you be alright as far as ground clearance with the dual exhaust? Good luck
Car: '82 Z28
New dual exhaust will be mandrel and as far as ground clearance goes... The guy who's going to do it is known for tucking the exhaust up as much as he can so I'm not worried. Size of the muffler should be 4 X 6 X 12. brodyscamaro, I've just now finished up the first tank of gas and gotta fill up later today lol. Haven't driven it all that much because of a stupid little oil leak at the back of the manifold. Redoing it today if there's a break in the weather then the miles will be put on more quickly
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
do you have any problem with that cam not making enough vacuum for your power brakes or do you have a vacuum resevior. thanks
Car: '82 Z28
Still have power brakes with no reservoir
Sometimes the pedal gets a tad harder but 99% of the time it's like when I had the 305 in there.
Sometimes the pedal gets a tad harder but 99% of the time it's like when I had the 305 in there. Supreme Member
Car: 84 camaro Z28
Engine: 434sbc
cool. i have AFR 195cc heads on the way. i snould have them in about 8 weeks. i don't know if i can wait that long
. anyway, i was asking because i am going to get a cam thats just a little bit smaller.
by the way you car sounds awsome. do you have a cat.
. anyway, i was asking because i am going to get a cam thats just a little bit smaller. by the way you car sounds awsome. do you have a cat.
Car: '82 Z28
sounds better in person (as always) lol yeah, the cat is still on there and it's not even gutted. Haven't gotten around to putting a "test pipe" in yet
It's on the to do list along with a million other things. Putting a Victor Jr on tomorrow after finding out the torker II doesn't line up properly with the AFR heads. It was only on there for the time being anyway.
It's on the to do list along with a million other things. Putting a Victor Jr on tomorrow after finding out the torker II doesn't line up properly with the AFR heads. It was only on there for the time being anyway. Supreme Member
Car: 84 camaro Z28
Engine: 434sbc
EvilCartman
correct me if im wrong, you did get the heads fully assembed from afr right? if so, did you have them upgrade the springs and retainers.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Originally posted by 25THRSS
You got 195 heads on a 400 block? Man that's small.
Originally posted by Mkos1980
One magazine put the AFR 180's on a 400 block and made 490 HP
Car: '82 Z28
Originally posted by heavy_chevy29
EvilCartman
EvilCartman
needs a better fuel pump. Member
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
how do u pass emissions in california with that engine? from what i heard, if its not stock, its not passing, or is ur car not registered?
thanks, john
p.s. it sounds freekin awesome man
thanks, john
p.s. it sounds freekin awesome manLast edited by 1989RS; Dec 8, 2003 at 02:44 AM.
Car: '82 Z28
thanks, john
thanks, john
I'm not at liberty to say
But one could swap motors every couple years
84z96L31vortec
Aug 20, 2017 12:16 AM
