H-pipe location
Old Dec 23, 2003 | 04:31 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
H-pipe location
When putting true duals on a third gen with an H-pipe, is there any advantage as to where the H-pipe is located?
Old Dec 24, 2003 | 12:55 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
To find out where to place the h-pipe you're supposed to paint the exhaust pipes, and then run the car. The paint will burn off where the H-pipe needs to go. However where it needs to go and where it can fit are two different things...
Old Dec 24, 2003 | 01:50 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're running a 'traditional' type dual, just behind the trans x-member the most ideal placement to keep it at the same level with the rest of the piping.
http://www.deadbird.org/a/du02.jpg
If that's not an issue or you're routing it differnt, kfoley nailed it.
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
