dual exhaust
Car: 1987 Z28
dual exhaust
is there any real binifits of power to run true duals on my car its a 305 with hedman headers and i was ganna run the true duals in the stock locationright next to eachother but i dont wanna do it if im ganna be losing power and i dont want it to be to loud
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
If you are going to stick with your 305, I would just do a single 3" Cat-Back. You don't need a true dual.
Car: 1987 Z28
if i did do it though would i be losing power or staying the same or gaining? as oposed to just having the hedman headers y pipe runing in the stock position with a cut out in place of the cae...the duals wouldnt have cats eather...and how loud will it be if i have that spiral cor muffler on the duals if i do that setup
I'm going to put headers on mine, with a cut-out before the cat. That way it stays legal and I'll just use the electric cut-out for more HP and sound.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
