Can this be done at home?
Old Jan 13, 2004 | 10:39 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I didn't realize the price exhaust shops charge until I started calling around, anyway has anyone ever done this at home; come off a set of Hedman long tubes with the hedman s-extensions then welded on an H-pipe, then a set of bullets or something similiar to bullets then some simple turn-downs in front of the rear axle? I have a friend I can borrow a wire welder from and I've got a sawzall. Does the h-pipe line up with s-extensions. I'd like to run my pipe and mufflers down each side of my driveshaft. Is there any problems I might run into that anyone knows of?
Old Jan 13, 2004 | 01:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/techbb2/sho...hreadid=204351
Old Jan 17, 2004 | 10:19 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just a tip, if the h pipe isnt within 6 inchs of your collectors its pretty much worthless as far as power is concerned. I know this is next to impossible on our f bodies. So basically it comes out to whether you want the "cool" factor of an h pipe or just want to go ahead and put straight duals on your car.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
drumstixer
Sep 29, 2015 03:02 PM
ironbmt
Sep 27, 2015 06:00 AM
RedLeader289
Sep 23, 2015 06:50 AM
