Ok guys, help me decide before my purchase!
Old Jan 25, 2004 | 05:10 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I am going to get 2055's. No sniffer here.
1) Should I have the air tubes chopped off, holes welded shut, then have the headers coated? Or should I just leave them on there?
2) If I did have them chopped, all I have to do is plug off where the tubes go now? Or would I have to bypass the air pump?
3) I am also thinking of a cutout. If I get the Y pipe coated, then take it somewhere for the cutout install, will this cause the coating to crack/chip?
Old Jan 25, 2004 | 02:13 PM
MdFormula350's Avatar
once u get the air tubes off the headers and plug each hole, u dont have any use for the smog pump any more, and just remove all that stuff it gets in the way anyway
after that i would then get the headers coated, a nice set of coated non air headers looks sweet.
as far the y-pip i wouldnt even bother getting it coated, but thats just me, with all the low spots i go over y-pipe touching happens.
cant say about cutting the coated y-pipe for a cutout, just add the cutout right after the y-ypipe.
Old Jan 25, 2004 | 02:45 PM
Car: 1988 IROC-Z
Engine: 427 SBC
But wont that make the exhaust longer??
Old Jan 25, 2004 | 05:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yea but either way you look at it you are going to need some custom fab work down there. Pretty simple but you will most liekly just take a few inches off of your I-pipe. That is what I did with my y-pipe and new cat. They were a bit to long with the reducer attached so I just cit off the flange on my cat back and went from there. I would though take those headers and cut the AIR stuff off and remove all of the AIR stuff al together. Have you looked at the non emission SLP's. You can get those coated without AIR all in one step. Sure they are more but by the time you add up your costs for the others it may be the same.
Old Jan 25, 2004 | 05:22 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I looked into them, and from what I read, I dont want the hassle
Old Jan 25, 2004 | 07:31 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
JetHot offers the 2055's already coated with the y-pipe coated as well. Mine were $520 delivered to my door, but I believe their prices went up. If you don't want the AIR tubes, I would email them and ask them if they can chop them off and weld them up before they coat them.
I would just leave the AIR tubes on it though, since sooner or later I bet all states will have emissions laws and you may have to change.
Old Jan 25, 2004 | 07:53 PM
25THRSS's Avatar
I did all the work myself. I cut off the tubes with an air grinder, ground the welds down, filed them smooth, had them welded up for $15 bucks, and then reground them down smooth. I doubt if you had someone else do it they would take all the time to make it look like they were never there in the first place. Just save the $ and do it yourself. It's pretty easy.
Old Jan 25, 2004 | 11:06 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Man, I dont know what I want to do. ACS gave me a very good price to chop and coat.
Old Jan 25, 2004 | 11:49 PM
25THRSS's Avatar
Try to find someone who has had the same thing done and see how good of a job they did. I can tell you though that my headers look like nothing has been touched and they came that way from hooker. If acs can do that then if you dont mind paying a little extra go for it, if not then i'de just do it yourself. Really it's simply, if you have a hacksaw and a file you are good to go.
Old Feb 2, 2004 | 12:29 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Just get coated 2055s and I would get the Y pipe coated(if you are not scraping it) so the exhaust would flow hotter farther. That should give the shorties very similar performance of coated long tubes. Also just leave the AIR tubes on. They don't hurt performance and you are helping the environment. Plus you never know what the laws will provide. I agree that it looks cleaner under the hood without them, but one could make the point that coated AIR tubes kinda look cool. Especially to the untrained eye.
Old Feb 2, 2004 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You might want to check out the info in this stickie above https://www.thirdgen.org/techbb2/sho...hreadid=213310 before you chop off the A.I.R. system.
Old Feb 2, 2004 | 06:51 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Ive read that before, I am not really worried about it. I am still undecided though.
Anyone got any information about the 2055's have an air tube backwards or something?
Old Feb 2, 2004 | 07:00 PM
five7kid's Avatar
If you have a factory carb'd engine, the driver's side check valve points to the front. 2055's have the driver's side check valve point to the rear, like stock TPI.
Old Feb 2, 2004 | 08:42 PM
85TransAm406's Avatar
Car: 1985 Trans Am
When i got my 2460s, the passenger side check valve pointed to the rear, and i had to flip it around to make it hook up correctly to the air stuff, why is that? Just curious, but now i don't have any a.i.r stuff at all. oh, on a stock 85 TA TPI 305
Old Feb 2, 2004 | 09:09 PM
five7kid's Avatar
They pattern the system after '86-up TPI.
Old Feb 2, 2004 | 09:14 PM
Car: 1985 Trans Am
cool, i didn't know that 85's AIR system was different.
Old Feb 3, 2004 | 12:38 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Is it possible to just plug the spot where the air tubes go, and leave it be for a bit? Or if I plug them, do I have to stop the pump from working?
Old Feb 5, 2004 | 06:14 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Old Feb 5, 2004 | 06:29 PM
five7kid's Avatar
I ran mine capped for 2 years (started the mods half an hour after passing emissions when stock, then finally hooked the system up when it was time to get it tested again).
But, I've got a carb'd system. I don't know if the stickie A.I.R.-delete stuff applies to me (I doubt it does).
Old Feb 5, 2004 | 06:33 PM
five7kid's Avatar
Oh, guess I should have said I capped off at the check valve mount, and I didn't run the pump. Easy enough to take that belt off on my system.
If you don't have it hooked up, I wouldn't run it.
Old Feb 5, 2004 | 08:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No. When I got my headers I took all of my AIR stuff out but left the smog pump on for a year. I only left it on because I could not get it out (torx bits and cramped areas are the devil). After a year the pump made popping and grinding sounds and started to sieze. That is when I got midevil on the pump and got it out. When I spin it now that it is off of the car it barely turns and makes a horrid gridning sound. The same thing happended to my buddies car. He left the pump on for about a year and he had the same outcome and sounds. We took his off and horrid sounds went away and his pump to was shot.
Old Feb 5, 2004 | 09:50 PM
Car: 1985 Trans Am
you could just run the smog-pump delete belt routing
Old Feb 5, 2004 | 10:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well if he has the serpentine set-up, which he does since his is a 88, you cannot just reroute the belt without taking off the pump. You can take the pulley off but the pump sticks out and the new belt will not clear it. The pump will need to be removed. With V-belt set-ups you can just take the belt off and be done with it.
Old Feb 6, 2004 | 10:50 PM
davehamilton's Avatar
AIR & why it is backasswards
Hello Guys, OKAY, All the AIR equiped hears are set up for TPI if you have TBI then you need to reverse 1 of the AIR inlet setups.
We will always work with you to provide the best and CHEAPEST products possible!!!
Just let us know how we can best help!!!
P.S. New e-mail Address------acsheaders@earthlink.net
Thanx 4 all the support!!!
LT1Formula
Nov 16, 2015 01:13 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
hectre13
Aug 26, 2015 08:17 AM
Street Lethal
Aug 14, 2015 08:25 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
