Hedman LT's and Angle plug pro lightnings?
Old Feb 3, 2004 | 10:25 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Anybody on here running pro lightning angle plug heads and hedman long tubes?
I'm getting a real *good* deal on some used angle plug 200/64 cc and used crane "gold" racing roller rockers and stud girdles from a road racer. I'm getting good enough of a deal on these that i'm buying whether i can use them now or not, but i'm almost out of money so new headers, or different heads aren't an option for another month or more, however I've got a perfectly a good converted lt1 intake, 30lb injectors and prom burning equipment sitting dormant, and I don't want to stick this stuff on stock heads.
Anyone running pro lightning heads and angle plugs with hedman long tubes?
Any one running angle plug heads in general on hedman long tubes?
How is spark plug clearance?
Did you have to use cut down spark plugs or anything else ridiculus?
And please real world experiences only. I know its says that these fit angle plugs but it also said floorboard modification needed . Add to the fact that different heads all have slightly different angles for their plugs and you've got a nightmare.
Old Feb 5, 2004 | 05:06 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I'll be using AFR 210 angle plug heads with my current heddman, I have looked many times and there should be zero problems at all running that set up.
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
