Universal Dual kit, need help
Old Feb 7, 2004 | 10:46 PM
insayne's Avatar
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
i got this jegs universal dual exhaust kit: Dual i have the stock exhaust manifolds. can someone send me a pic of a 305/350 with stock manifold? and how whould u recommend install this kit with stock manifolds? any help is appreciated.
Old Feb 8, 2004 | 08:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would recommend you send it back and get a system that will fit the car.
If you insist on using it, the reducers intended to go on the header collectors won't fit anything - they're about $20 of the price you paid. You might be able to use a few of the pipes with some equipment typically only found in exhaust shops. But basically, you bought something that wasn't intended for our application, and certainly not for use with stock manifolds.
Old Feb 8, 2004 | 10:37 PM
insayne's Avatar
Engine: 305 H.O
what if
what if i get hedmen longtube headers? then it will fit perfect right?
Old Feb 9, 2004 | 12:05 AM
five7kid's Avatar
No. Where are you going to put the (not included) mufflers?
Old Feb 9, 2004 | 07:24 AM
insayne's Avatar
Engine: 305 H.O
what
what do you mean no? it will work perfectly with longtubes, and i got 2 dynomax race bullets in gona but in the middle between the headers and the bend out twords the wheels
Old Feb 9, 2004 | 07:26 AM
insayne's Avatar
Engine: 305 H.O
im aware
the exhaust is prolly gona be 4" at its highest point, and thats about how high my gfxs are off the ground, since theres more room under there it should fix with half decent ground clearance, if i can get over speedbumps im good
Old Feb 9, 2004 | 09:32 AM
five7kid's Avatar
If you had a 68 Camaro or a 72 Nova or 81 Firebird, they would work with long tubes. Then along came the '82 F-body, and everything changed.
Yes, you "can" use such pipes on a 3rd gen. The first problem lies exactly where you speculated - ground clearance. The second is getting it to route where there's the least bit of space to clear body & chassis. Unless you have access to tube bending & welding equipment, you'll probably have to pay an exhaust shop to modify it to make it fit. When you get done, you'll have an obnoxiously loud exhaust that scraps on every little dip & bump in the road - let alone speedbumps, that probably cost you more than an aftermarket 3rd gen system would have cost.
A system designed to route where the factory put it is much less problematic, and will flow well enough to support all but the most outrageous street engine.
But, you "can" use that universal kit if you insist.
Old Feb 9, 2004 | 11:46 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
It will be low as sin and you will be able to see the entire exhaust system hanging below the car from the side and back.
Old Feb 9, 2004 | 01:40 PM
insayne's Avatar
Engine: 305 H.O
jegs restocking fee?`
does jegs charge a restocking fee?
Old Feb 9, 2004 | 01:42 PM
insayne's Avatar
Engine: 305 H.O
and
im prolly gona get a hooker cat-back *** i wish i saw this befor i ordered that pos, its like 20 bucks more to, now im gona loose shipping it back plus restopcking cuz im dumb =| are the hooker cat-backs loud? i want a loud mean sounding exhaust, and most of all i want it to sound nice when i get on it, cuz thats what im always doin anyway
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
