hooker super comp LT's..which starter?
Old Feb 24, 2004 | 02:46 PM
5L EaTeR's Avatar
well my motor is finished and im test fitting my headers before dropping it in...and the passenger side header wont clear the adjustable position mini-starter i bought, even when i adjust it to every available position!
how the %*#@ did you guys get your Hooker long tubes to clear the starter? what starter are you guys going with? im looking at aftermarket high-torque mini starters...but cant find one that clears
HELP!!!
Old Feb 24, 2004 | 02:54 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I use an AC delco 1994-1997 LT-1 T-56 starter. I have plenty of room and I have Coated 1 3/4" Hooker Super Comp Long tube headers.
Old Feb 24, 2004 | 02:57 PM
5L EaTeR's Avatar
hmm, ya those my headers exactly....but i wanted something a little more high performance (and lighter) than the LT1 piece
any suggestions on an aftermarket piece?
thanks for the input though. if all else fails i guess ill go with the LT1 starter.
Old Feb 24, 2004 | 03:01 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The LT-1 six-speed starter IS a gear reduction light starter with good torque (good for upto 11:1 compression easily). Why spend more money when the above will do the job perfectly AND clear the headers at the same time!!
Old Feb 24, 2004 | 03:04 PM
5L EaTeR's Avatar
interesting. ya im running around 11.3:1 CR and i didnt know if the LT1 starter would be adequate. that sounds good! im gonna check it out, thanks a ton.
....i dont suppose you'd know of anyone selling one in good condition right now?
if not i guess im off to cz28.com to chk the buy and sell
Old Feb 24, 2004 | 03:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its already been said, but yea, the GM style ministarter is what you need.
i got (probly the same) multi position ministarter.... wouldnt clear my headers...
i eventually gave up and shipped it back to summit and got the summit ministarter... works great.
Old Feb 24, 2004 | 03:32 PM
5L EaTeR's Avatar
ya i think thats the router im going with. i just found a brand new one on cz28.com for $80 +shipping. not bad since theyre $120 new.
boy this board never ceases to impress me with the speed and quality of responses.
thanks guys!
Old Feb 24, 2004 | 03:53 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I used a newer GM downsized starter. It gives a bit more clearance and should cut down on heat soak.
Old Feb 24, 2004 | 11:33 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i went to Jegs and ordered there Jegs Prostartr' for $155, clears my hookerlong tubes no problem, i did have to trim a little corner off becuz it was hittin the oil pan like the edge near the bolts.
Old Feb 25, 2004 | 12:14 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
just using a standard sbc mini starter from hamburger- i did have to change the clocking on the starter, but it fits fine!
Steve
Old Feb 25, 2004 | 07:27 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I am using a CSI ministarter with no problems and the fitment is fine with the long tubes.
Tim
Old Feb 25, 2004 | 10:12 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
This was the same question I was just coming to ask! If an LT1 starter is what works, maybe I'll look for one of those.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
