Slp Exhaust, questions on adding headers.
Old Feb 29, 2004 | 10:21 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
I have an 87 formula i bought a while back with 3" slp exaust. It has stock exaust manifolds and i don't know what to get for headers becuae im worried about what will fit with the exaust system there, i hear that short headers do almost nothing for performance, and that long tubes are not worth the work of putting in.
Also will either short or long tubes bolt to the stock Y-pipe? will a Y-pipe included with the headers fit into my SLP exhuast? im all confused over all this information. I need advise.
the car is making around 350 hp, and soon around 400 after cam swap and head work, im planning on adding nitrous or supercharger next after i figure out which works better with the engine set up.
so i will want exaust thats good for 500+ hp.
Old Feb 29, 2004 | 11:50 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you slp headers you will need their slip fit connecter from the Y pipe to the cat or exhaust. thats what I used.
Old Feb 29, 2004 | 04:13 PM
Engine: 5.8Ltr 356
how is that setup workin out? are you satisfied with it?
Old Feb 29, 2004 | 05:11 PM
DJP87Z28's Avatar
Its been on since my engine swap 2 1/2 years ago and everthing is running great. The SLP set-up was a good decision on my part.
Old Feb 29, 2004 | 05:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Slp Exhaust, questions on adding headers.
Wrong. Headers of any kind will allow your motor to make tons more power at ever RPM point. They do tremendous things for performance. I believe a stock 350 TPI will pick up 26 to the wheels with shorty headers, high flow cat, and cat back. Any headers that you buy that are tailored to our cars should come with a y-pipe. There are only a few that don't. All of those y-pipes will end in the same location allowing you to reuse whatever exhaust you have that is routed the same as stock. Sine the car has an SLP set-up on it you will have no problems. There may be a little fab work to connect the two but they will line up.
Old Feb 29, 2004 | 07:14 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I have the 1 5/8 slp headers w/ y pipe and 3" pipes going into my Borla exhaust. Sounds real loud when you first start her up in the morning. Now all I need to do is put on my catco converter on. The headers is one of the best things you can do to open up performance on your f-body.
Old Feb 29, 2004 | 07:26 PM
Engine: 5.8Ltr 356
Thanks guys, Now, im assuming that if i buy long tube headers with a y-pipe, that means that after i eventually get the headers in there, the y-pipe should go to the same place that the stock y-pipe does?
Old Feb 29, 2004 | 08:10 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Not true with long tube set-ups. That is an entirely different animal and are usually used for true duals or custom stuff. Nolong tubes come with a y-pipe for our cars. You have to buy an off the shelf on or get one fabbed up.
Old Feb 29, 2004 | 08:48 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
500+ hp might be a good canadate for a true dual set-up.
Check out the sticky at the top of the page for pics and ideas.
-chuck
Vintageracer
Jan 10, 2020 05:33 PM
midias
Aug 22, 2015 01:42 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
