removing cat
Old Mar 8, 2004 | 02:10 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
removing cat
question I'm removing my cat on a 89 completely stock, the small tube that is on the cat where does go and what does it do. Can I simply cut it and leave it open or what.
Old Mar 8, 2004 | 02:43 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
It goes to the smog pump, delete this pump (see elswhere on this board), and get rid of the small hose as well!!
Old Mar 8, 2004 | 02:45 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
I believe that goes to an O2 sensor or smog pump. If you have to smog the car you need it. If not???
Old Mar 8, 2004 | 03:00 PM
gscz28's Avatar
Car: 89 iroc
smog pum
I've seen all the threads on this, But I'm looking for some good pic's or of how to and what to do with the hoses that go to the fire wall....That is really an ungoddly eye sore...
Old Mar 8, 2004 | 03:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The air tube goes to the back of your smog pump on your accessory brackets. It adds air to the cat to help with the chemical conversion in there. That is the non technical way of explaining it to keep it simple. It also has a diverter valve that sends the air at certain times. If you remove the cat just leave it open. It will just pump air into the atmosphere. You may just want to tie it down so that it doesn't bang around. If you are removing the AIR system than that tube will come out.
Old Mar 8, 2004 | 03:18 PM
gscz28's Avatar
Car: 89 iroc
lets kick this dead horse some more. I'm at the car right now, but I thought there was a hose that went from the a/c unit to the pump as well. what do you do with that?
Old Mar 8, 2004 | 05:14 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No. The AC and smog are two differnt set-ups completely detached from each other.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
