Electric Cutout
Old Mar 16, 2004 | 11:27 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Electric Cutout
Where is a good place to get electric cutouts at a decent price? I am going to need 2 because i am running dual exhaust.
Old Mar 17, 2004 | 09:11 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
mine cost $100 bucks....the McCord Power Plate...they have a pretty good warranty. That's about the base price..anywhere between $100-$200 bucks....I love mine.....one of the best "add on's" I've installed
Old Mar 17, 2004 | 09:14 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Same here. I only run 1, but they sell them pre-wired as a pair for like $200. The cool thing is, the prewire the whole thing so all you have to do is hook up power and ground. I put in a relay to be sure not to drain the battery. They go from full closed to full open in about 2.5 seconds. It's kind of cool because you can just crack it for a little more noise, or open it all the way for the fullest effect.
Old Mar 17, 2004 | 09:50 AM
White91GTA's Avatar
Engine: 5.7L TPI
Thanks for the replies guys...
Old Mar 17, 2004 | 06:50 PM
fast86z's Avatar
Car: 1984 Pontiac Trans Am
where did you order them from?
Old Mar 17, 2004 | 09:22 PM
White91GTA's Avatar
Engine: 5.7L TPI
the only place to order the mccord power plate is from mccord.
http://www.mccordcg.com
Old Mar 21, 2004 | 03:20 PM
raptere's Avatar
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
wrong link try this one http://www.mccordcg.com/mpp/mpp.htm
Old Mar 21, 2004 | 03:28 PM
White91GTA's Avatar
Engine: 5.7L TPI
Thanks for the correction on that.
Old Mar 23, 2004 | 07:28 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
so is it half or all the way open all the way closed. or can you vary it.
Old Mar 23, 2004 | 08:04 PM
Engine: 5.7
you can have it closed....shut..or anywhere in between....it's alot of fun
Old Mar 23, 2004 | 10:36 PM
raptere's Avatar
Would any one be interested in a group purchase, on these i know i would be in for two, if other people are , does any one know how to get one started?
Old Mar 23, 2004 | 10:37 PM
Engine: 5.7
email McCord....I'm sure they can set TGO up with a group purchase....
Old Mar 24, 2004 | 08:44 AM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
check out www.quicktimeperformance.com for there QTEC, i bought it and picked it up locally with them. Its a real nice peice and they are good people
Old Mar 24, 2004 | 09:53 AM
White91GTA's Avatar
Engine: 5.7L TPI
i would be up for a GP...let me know when so I can try to save the money for it.
Old Mar 24, 2004 | 10:00 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
im up for a GP definantly, ive been wanting an electric cutout for ever, just dont want to spend the full amount for one
Old Mar 24, 2004 | 11:24 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
do yall really run it inbetween open and closed? Mine just sounds like a big exhaust leak when it's only cracked open.
Sounds wicked with it wide open though, I have mine right after my headers I do get a slight leak with it all the way closed. Has anyone tried to fix this? I hear it's a common "problem".
Honestly though, if you don't have a little more aggressive cam, I don't think it would sound good (at idle anyway).
I love mine, I got mine with the group purchase a while back, from the McCord link.
Old Mar 24, 2004 | 11:54 PM
Engine: 5.7
never had any problems with mine...I do oil it up every once in awhile though. When I run mine...I usually run it wide open.....loud as hell....sounds like a NASCAR...especially with headers ....just better forget about listening to the stereo when the power plate is open!
Old Mar 25, 2004 | 12:15 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
or talking especialy on the free way.
Old Mar 25, 2004 | 06:47 PM
jocww's Avatar
so do thet have exhaust leaks
Old Mar 25, 2004 | 07:50 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
yes.
Old Mar 26, 2004 | 04:43 PM
SNIPING92BIRD's Avatar
Car: 1989 GTA / 92 Z28
Engine: 350ci
Transmission: 5 speed
how do we get em installed...locall muffler shop will do it?or i got to know someone who can weld them up...i mean how does that work?....oh and im up for a GP
Old Mar 26, 2004 | 05:50 PM
jocww's Avatar
so how many others get exhasut leaks
Old Mar 26, 2004 | 11:02 PM
Engine: 5.7
I have an exhaust shop weld my cutout in....but I actually installed the McCord Power Plate...it was very easy to do....just ground it, and run the power to the fuse box or some other power source. Depending on where you have your cutout installed...I just took my passenger seats out (front and back) ran the wiring harness under the carpet, took out the plug in the back floor board under the passenger seat, and ran the wires that way..it was easy....guess it just depends on how well you know your car.
Mine doesn't leak at all....maybe if you got underneath the car...and put your ear up to it..you might hear a little something...but nothing major here.....
Old Mar 27, 2004 | 12:56 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
count me in on the GP
Old Mar 27, 2004 | 04:15 PM
Engine: 350ci
thnx 84 custom....my concern was who can weld up the cut outs to the pipes...the reason i asked is cuz i know the shops wont do the str8 pipes on the car (illegal) unless its someone you know... but since you said the exhost shop did it on your car then i shouldnt worry about it
Old Mar 27, 2004 | 11:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
keep in mind he lives in another state and their laws maybe different.
Old Mar 29, 2004 | 08:51 PM
Engine: 350ci
good point there TraviZ...I guess i got to look around...thnx
Old Mar 29, 2004 | 09:01 PM
Engine: 5.7
yeah, here in Indiana, we have emission laws...but they are not enforced, exhausts are not checked or anything. I guess a cop could pull you over and look under the car though. I know a few people at a few shops that will do that kind of stuff for me...I had my dual cats cut off too...no restiction at all...I just hope the laws don't get enforced!...but if they do...that's why I bought the Edelcbrock TES headers with air tubes...
Old Mar 29, 2004 | 09:10 PM
Engine: 350ci
why did you have your dual cats cut off if you have the cut outs? or that was before the cut outs...
Old Mar 29, 2004 | 09:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
so wheres the group buy on cut outs?
Old Mar 29, 2004 | 09:18 PM
Engine: 5.7
when I bought my car...my dad and I drove it up from Chicago..and on the way home...the cat's blew out..sounded like crap...so instead of having them replaced...I just had the exhaust shop weld straight pipe in place of them. My cutout is placed in my "I" pipe, under the passenger side back seat...
Old Mar 30, 2004 | 06:35 PM
jocww's Avatar
count me in for the gp i think 6 or so. if u guys dont do it i will start it
Old Mar 30, 2004 | 06:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
which company would u be going through?
no matter what though, im in on this
Old Mar 31, 2004 | 12:16 AM
jocww's Avatar
the cheaper better of the 2
Old Mar 31, 2004 | 12:36 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well jocww, u better start emailing some companies
Old Mar 31, 2004 | 01:05 AM
jocww's Avatar
ill do the mc
Old Apr 4, 2004 | 12:27 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'd be up for it if I can convice my dad about the problems with a cutout leaking.
Anyone have more info on cutouts leaking?
Old Apr 4, 2004 | 12:29 AM
Engine: 5.7
as for mine...if I just stand by my car...I can't hear any leaking at all. Now...if I get underneath, close to the cutout..I can hear it...just barely though. I'm very picky about things like that...but this dosen't bother me at all....
Old Apr 4, 2004 | 01:18 AM
25THRSS's Avatar
I like the design of the qtec better
Old Apr 4, 2004 | 10:41 AM
Engine: 5.7
that's cool....but why? I've heard Qtech and McCord are about the best ones out there. They have a good warrenty and are both made out of good material
Old Apr 4, 2004 | 07:42 PM
jocww's Avatar
how much is q tec
Old Apr 4, 2004 | 08:00 PM
  #42
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
wheres the GP?
Old Apr 5, 2004 | 10:20 PM
  #43
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The Qtec is around 150 without the cutout.
QTEC
Cutouts QTEC
Old Apr 6, 2004 | 12:57 AM
  #44
jocww's Avatar
q tec is way more than what im planning on spending. when i start the gp im going to do the mccord
Old Apr 6, 2004 | 01:14 AM
  #45
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thats cool. hurry! lol
Old Apr 6, 2004 | 06:00 PM
  #46
White91GTA's Avatar
Engine: 5.7L TPI
when it gets started...hopefully i have the money b/c i really want them
Old Apr 8, 2004 | 02:56 AM
  #47
launchpad's Avatar
count me in too!
Old Apr 12, 2004 | 01:41 AM
  #48
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I have the qtec, it's pretty cool. There is a slight exhaust leak. But if I hold the switch in the closed position it stops, then I release and it comes back. Not that much, it doesn't really bother me. It is definately one of the coolest things you can buy.
Old Apr 12, 2004 | 02:17 AM
  #49
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
count me in on the GP, Ive got an awsome exhaust guy that would weld it in for me and Im getting my tax return real soon. 3" please.
Old Apr 12, 2004 | 04:30 PM
  #50
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i setup a GP with mccord last year. if ya'll want to do another, everyone interested that HAS THE MONEY NOW pm me, and i'll get the ball rolling, then everyone else that wants to jump in, can.
