ORypipe
Old Mar 17, 2004 | 02:48 PM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
ORypipe
how much do you think it would cost to have a orypipe like this made
Old Mar 17, 2004 | 02:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
About $200-$300, plus coating.
Old Mar 17, 2004 | 06:00 PM
25THRSS's Avatar
You could get a better one that comes with headers too. They're known as the Hooker 2055's. Cost about $360
Old Mar 17, 2004 | 08:24 PM
1fast91rs's Avatar
Car: 1991 RS
i was thinking of getting the hooker shorties(HOK-2460) from summit racing for $149.88
Old Mar 17, 2004 | 08:32 PM
25THRSS's Avatar
They're good headers, but they do not come with a y pipe. In the end they're prolly not worth it over the 2055's.
Old Mar 17, 2004 | 08:45 PM
1fast91rs's Avatar
Car: 1991 RS
are the 2055s LT headers i cant find them in the summit catalog do you have a link?
Old Mar 17, 2004 | 08:47 PM
25THRSS's Avatar
They are shorties with a similar design to the 2460 with the exception of the ball flange to mate up to the y pipe that comes with them. Just about the best headers you can buy for our cars.
Thunder Racing sells them at the top of the page. You can find pics of them by doing a search as well.
Old Mar 17, 2004 | 11:45 PM
five7kid's Avatar
Sponsor ACS above will sell them coated.
In Summit, put in "HOK-2055" in their p/n search window. $359.95, "should ship by today". Some say the Hooker ceramic coating isn't the best quality.
Old Mar 20, 2004 | 01:50 AM
1fast91rs's Avatar
Car: 1991 RS
should i just order them painted black and have them sent to jet hot to be coated?
Old Mar 20, 2004 | 08:47 AM
five7kid's Avatar
Or just order them from Jet Hot or ACS directly. They both sell them coated without you having to handle them.
Tell either you're a thirdgen.org member and they'll give you a nice deal.
Old Mar 22, 2004 | 01:04 AM
1fast91rs's Avatar
Car: 1991 RS
will the 2055s bolt up to my stock ypipe?
Old Mar 22, 2004 | 09:08 AM
five7kid's Avatar
No. The 2055's have their own y-pipe included. They are intended for '86-'90 TPI single-cat application, so your cat won't fit their y-pipe, either. The typical approach is to replace the entire system with aftermarket parts for that application.
Old Aug 21, 2005 | 12:36 AM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
2055's
i have a 91 z28 305,single cat,is the ypipe a 3''size that comes with the 2055headerpipe?if so will the catco9118 be a good alternative to my stock cat which is only what 2 1/2in at the inlet end,i bought aset of 2055'sand hope there going to fit but ive never had a chevybefore,and never did a header install either,the seller says that they will fit my lb9,but that the ypipe is to big for my stock cat,need to find replacement,do you know what size the stock intermediate pipe is that hooks up to cat outlet end?thank you for all info cuda69
Old Aug 22, 2005 | 09:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Cuda69, come over to the SoCal section and ask there if you dont get a response here. We might be able to help.
Stock y-pipe for a 305 is a 2.25" outlet on a single cat car, and 2.75" outlet on a dual-cat car (after the cats, which are 2.25" each). If you have a single cat, your best bet is to get your muffler shop (like my dad's shop ) to make the y-pipe 3" outlet to mate up to a Magnaflow cat converter, and 3" outlet to an aftermarket cat-back. Or 2.75" reducer to your stock cat-back untill you replace it.
Old Aug 22, 2005 | 11:20 PM
cuda69's Avatar
Engine: 305TPI
stock cat
turns out hooker doesnt make a 3''ypipe so it must be 2 1/2''which i should be able to sweat to fit my cat i have now,then upgrade later,i think a shop can make the connection work,were is your dads shop in what city,how for from me is it here in san jose?is the inlet on the stockcat a 2.25 slip fit?so i can just run the ypipe right in and be done with it?
Old Aug 22, 2005 | 11:28 PM
cuda69's Avatar
Engine: 305TPI
i thought the ypipe that came with the 2055's was a 2.50 slip fit,i was going to just stick it into mystock 2.25 cat if i can get it modified at the muffler shop to fit,dosent that seem possible?i was told they could shrink the end down to fit the 2.25 inlet on the cat i have now?91z28LB9vert,t-5,singlecat,pro5.0,k&nfilters,need info, help to make these 2055's fit my stock setup,cuda69
Old Aug 23, 2005 | 12:49 AM
Kevin91Z's Avatar
Oh, your location says Southern California, so I thought you were down here near us. My dad's shop is in Orange County, near Disneyland.
I dont know anything about doing stuff in your driveway. I've been spoiled and do my mods in my dad's garage. Perhaps someone with more knowledge of Hooker 2055's can help here. I have only installed SLP's (both sizes) on my car.
Old Aug 23, 2005 | 01:15 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
hooker 2055's is a 3" Y pipe that is a slip fit for a 3" cat..
i have it..
thaemcee2
Feb 23, 2013 07:29 PM
