hedman LT install...
Old Mar 20, 2004 | 10:40 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
trying to finish up my motor swap, and I'm installinf hedman LT's with 1 3/4 primaries, ceramic coated.... my driver's side is in. my pass side is hitting on something, and i can't tell if it's the transmission ear or the A-arm. anyone know? what do i do to fix it? also, do i need a mini-starter?
Old Mar 21, 2004 | 12:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably the A-arm mount, most people have had to grind it down slightly to fit.
By the way, the Hedman LT's are 1 5/8", not 1 3/4"
Old Mar 21, 2004 | 10:37 AM
Car: 1982 Trans Am
Engine: 383 chevy
I hate it when i get let down. ( i measured 'em... last time i trust anybody sellin stuff.) either way, they're not fitting. now, when you say grind down the a-arm, what do you mean? what part? how much? anybody have a pic of this I can see? I don't want to grind down too much, or grind down the wrong part. any help would be great.
Old Mar 21, 2004 | 12:24 PM
biff85ta's Avatar
Car: 04 Vette
Here you go.
https://www.thirdgen.org/techbb2/sho...ghlight=hedman
Old Mar 21, 2004 | 12:43 PM
Car: 1982 Trans Am
Engine: 383 chevy
thanks. that helps a good bit more, but I have an 82, so i was looking for people who had carb setups, and anything they did to make it go easier. I think I may be able to get away with cutting the A-arm and it'll work. the header is in, so I guess I'll just have to pull out the mount bolt, lift the motor to the side a bit, and pull it back out..... we'll see. thanks for the help guys, and keep it coming.
Zell1luk
Sep 29, 2015 10:36 AM
italiano67
Sep 22, 2015 08:42 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
