slip connection
Old Apr 4, 2004 | 07:17 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
slip connection
the slip connection on the hedman y-pipe under the oil pan....how should i go about it....i dont have acess to a welder.....but i can takeit somewhere it get it welded....how should i "tack" it in place....what do you guys recommend.....any other adivce for the swap would be good too but i shouldnt have to much trouble....im only 16 but ive already done one motor swap and tore down a 305 and rebuilt it
Old Apr 4, 2004 | 07:25 PM
Z28GEN3's Avatar
a very temporary solution might be a band clamp, it should fit rite in there neatly, that is what i plan on doing until i get the car to the exhaust shop, i just gas welded on the O2 sensor bung.
Old Apr 4, 2004 | 08:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Just use a band clamp.
Old Apr 5, 2004 | 12:34 AM
Car: 83 Camaro
Transmission: th350
band clamp???i think i know what you are talkin bout but i just want some clearification
Old Apr 5, 2004 | 02:03 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Can you leave it with a clamp like that or should I get it welded for sure?
Here is a pic Ben...
Old Apr 5, 2004 | 07:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
bolt it all up with the slip fit.
drive it to the muffler shop...
they'll tack it along the bottom..
then go home, unbolt the Y pipe, take it back to the shop, and they'll weld around it.
since most muffler shops dont prep the weld, and you cant have it too sloppy (tight fit between Kmember and pan), go over it with some sandpaper and brake cleaner near where hes welding before you bring it back to them.
lil bit of a pain, but it works..
athough..... you could always use this as a excuse to get a cheap 110v wire welder.... :lala:
Old Apr 5, 2004 | 10:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by MrDude_1
...you could always use this as a excuse to get a cheap 110v wire welder....
https://www.thirdgen.org/techbb2/sho...hreadid=231639
Of course, you left out another possibility - borrow a cheap 110V wire welder...
Old Apr 5, 2004 | 10:44 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
My Headman Y pipe came with a clamp for that. The U bolt style one. Hasn't leaked a bit in 4 years.
Old Apr 5, 2004 | 03:32 PM
Z28GEN3's Avatar
just do it all at once save the trip. although i like idea of buying a welder. just imagine the things you could do with one
Old Apr 5, 2004 | 06:15 PM
My Y pipe is ceramic coated...will that effect the weld at all? Also, I know a buddy of mine has a stick welder. Is that okay for this type of job?
InfernalVortex
Apr 20, 2021 11:31 AM
jrdturbo
Mar 31, 2016 02:58 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
