air?
Car: 84 firebird
Transmission: manual
air?
what all has to be done to remove the air system besides plugging the exhaust, and removing the pump and hoses, anything with emmisions? or with the intake manifold? if i remove this and my air conditioning how many ponies will it add? thanks will
84 firebird 305 5 speed
Transmission: 4L80E/4L80E
Welcome aboard.
It won't add any ponies. The only possible benefit from a performance standpoint is a reduction in weight.
And, of course, the removal of A.I.R. is an "off-road only" modification...
Car: 1991 Chevy Camaro
Engine: 305 TBI
It won't really add any horsepower but it will definetely clear up some room in the engine compartment. You can also remove your washer fluid reservior for some more room. Removing the AC will really add some room, too. I just removed my smog pump and reservior last week and it was well worth it.
All you have to do is, remove the pump, remove all of the hoses and that big black box (I forget what it is called), remove the AIR tubes from the exhaust manifold, plug the holes with 1/4" pipe plugs, buy a new 96.8" 6-rib belt, reroute the belt, and you are done. It is pretty easy.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Of course, if you have emissions testing (or even an "visual inspection"), be prepared to fail especially the exhaust sniffer test. You may still pass, some do, but a lot fail. Just my two cents.
Have a Great Day!
- Vern
Have a Great Day!
- Vern
Car: 84 firebird
air
i dont have emmisions testings, plus the car is getting hobbyist plates soon so i wont have to worry at all, plus when i did take it to emmisions it passed with flying colors.
