can i get duel exhaust!!
Old Apr 21, 2004 | 05:05 PM
joneboyy's Avatar
Car: '82 Z28 Indy pace car
Transmission: 4 speed berg warner
i went to a muffler shop to get duel exhaust for my car last week, the man said that since I live in CA it will not pass smog, but then I asked if it would pass if I had 2 oxygen sensors and he still said no. is there any way around this???
Old Apr 21, 2004 | 05:36 PM
chad89ta's Avatar
thats bull s**t he just didnt want to do it,cause its not easy to run.email me ill show you some good ideas,www.provgolf4u@aol.com
Old Apr 21, 2004 | 07:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will most likey not pass visual but with cats you should still pass. You cannot add 02 sensors. 3rd gen systesm only have one. I would stick with a large diameter smog legal 3" set-up. Much cheaper and legal.
Old Apr 25, 2004 | 04:35 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
wouldnt it work the same with dual or single because the o2 is only in the left header collector before the y-pipe, so it thinks its dual exhaust because it hasnt met the y-pipe yet, seems like it wouldnt fail visual if you have two cats.
Old Apr 27, 2004 | 12:57 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Maybe if you ran the dual exhaust in the stock location. Put the two cats where the dual cat option camaros had them. Just say that your car had the dual cat option. Now I know and you know they didn't offer the dual cat option 'til later, but is the inspection guy going to know that.... probably not, unless he's a camaro guru. Now when you go to the exhaust shop to get it done, you might be able to drive or trailer it there with NO exhuast on and tell the guy that it had the dual cats on it, but your dog ate your y-pipe (insert your own excuse here). It's going to be expensive (hard) to run in that location, but I don't know how you're going to get it done otherwise. Best bet would be to find someone who knows someone who works at an exhaust shop and have them put them wherever you want, but you are in CA, so you might be screwed when it comes to inspection time. Here in Tx, the exhaust shop says if you bring it in with nothing on it, then how are they supposed to know if it had a cat on it before.... they just can't remove or move the cat.
Old Apr 27, 2004 | 01:00 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Or just buy a used dual cat y-pipe and have them fab dual exhaust from behind the cats.
Old Apr 27, 2004 | 05:34 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Why go through the hastle??? Your running a 305, all the aftermarket single exhausts will be all you need plus they are legal!!
Old Apr 27, 2004 | 11:17 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yea, i'd have to agree, unless your pulling 300+ hp on that motor, dual exhaust will be overkill.
Old Apr 27, 2004 | 12:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If Herr Inspektor had a fight with his wife before leaving for work, all of the above suggestions could be cause for him to fail you. The only modifications allowed to the exhaust are certified replacement parts for the year, model, and engine type. Dual cats were not offered on carb'd cars, so you'd have to change to a TPI system that did - along with all of the other things that went with the TPI engine, and have it inspected/tested as that later year model. Same thing for 3" cat, there was no such thing offered in 1982 or for any year factory carb engine (although the L69 was closer).
You'd probably raise fewer eyebrows with a single 3" cat, but technically he could still fail you. I managed to pass here, and they do a full inspection, but all they apparently cared about with regard to the cat was that it was there and the sniffer said it worked. They didn't happen to notice that there wasn't any EFE valve, either that or they didn't care.
If you could sneak a dual-cat system past them, you could complete the system as a custom dual because they don't care what you have past the cat(s).
As previously stated, even the dual cat cars (which is the closest the factory came to dual exhaust on 3rd gens) only had one O2 sensor. The computer wouldn't know what to do with 2 inputs.
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
leighgrils
Oct 9, 2015 09:38 PM
david068513
Sep 18, 2015 10:36 AM
Ironhead38
Sep 7, 2015 02:26 PM
