2055's+vortec's=y-pipe<
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Just curious if anyone is running vortes heads and the hooker 2055s. Does the y-pipe fit ok, or does it need to be modded? Just curious because I'm interested in getting the y-pipe coated as well, but if it needs to be modded, I probably won't.
My hedman y-pipe needed an extension piece welded in when I did the swap last year, but the pipe also took a little abuse in the downtime.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
don't see why it would, isn't vortec heads just like any other sbc head as far as exhaust port? are the taller or something?
Engine: LO3;383tpi
I'm not sure. Last time, the y-pipe had to be cut and welded. But that may have been partiall because I let that portion of the exhaust hang free and snagged it on a couple of places while moving the car around. I knew I was going to need to change my exhaust though.
