restricted?
Old May 24, 2004 | 01:33 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
restricted?
right now im running dynomax headers (1.5") modded hedman Y pipe to work with the dynomaxs (2.25" downtubes to 2.5") and a 3" high flow cat. i feel like this setup was probably sufficient when the engine was stock but now im looking into a cam, porting the heads and a few other things so im thinking ill have outgrown this header setup witht he new mods. i was thinking i should get some new hooker or hedman 1 5/8s with a new Y pipe as well. but i figured id ask if its worth it, should i stick with what i have or upgrade? if im gonna loose significant power with what i got then i should upgrade, but if the difference is going to be like 5hp then forget it. what do u guys think?
Old May 24, 2004 | 01:42 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
since the exhaust is one of the more restrictive things on these cars, so on another hand it may be benificial to change them esp. if you plan on more mods, like porting heads or intake, id prob port the intake while it was off anyow.
Old May 24, 2004 | 08:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The exhaust you have now will suffice. You will really benifit from larger than 1.5" primaries once you get past 300hp range. I don't know if changing headers right now would be worth the price and effort.
Old May 24, 2004 | 12:03 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
this is for a 305 BTW, also with the new mods it should have over 300hp. just tryin to give as much info as possible.
Old May 24, 2004 | 04:19 PM
Engine: 383, L69
As long as the rest of the exhaust is up to par, they wont hold ya back no more than a few ponies. So you could stay with them.
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
BWilcox
Sep 20, 2015 12:19 PM
ericjon262
Sep 11, 2015 06:07 PM
