Alternator brace?
Old Jun 2, 2004 | 09:04 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Alternator brace?
Hey guys, you know how there are some black metal braces connected to the manifold bolts? For example I have an alternator brace and a power steering one both connecting to the first manifold bolt.
Do I have to reattach these? I dont see how I can, the bolts that came with my 2055's are small enough as it is! If I put those braces in front of the bolt, im lucky if it will screw in a half turn! Not to mention the headers are much thinner, would the braces even line up?
Old Jun 2, 2004 | 09:07 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Follow the directions that came with the 2055's. Cut off one leg, use the spacer between the header flange and the bracket with the original bolt (the spacer plus the flange will be the same thickness as the manifold was).
Old Jun 2, 2004 | 09:13 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
use a spacer, or use a long stud, tighen the header with a nut, then using another 2 nuts, sandwich the brace on the stud.
Old Jun 2, 2004 | 09:19 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks for the reply guys. I did read their directions, but some of the stuff in there is not necessary. But I actually didnt see anything in there about it Just wanted to make sure.
There should be three spacers that came with the headers correct?
Old Jun 2, 2004 | 12:23 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
yep 3 spacers
Old Jun 2, 2004 | 06:08 PM
25THRSS's Avatar
just leave the "brace" off, it's not needed.
Old Jun 2, 2004 | 10:09 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Mine had a picture on the back of the instructions showing what to cut. Took about 10 minutes or so, to cut it, and then smooth it out so it doesn't look like a hack job.
Old Jun 3, 2004 | 12:22 AM
what did you cut it with?
Old Jun 3, 2004 | 01:18 AM
25THRSS's Avatar
just to clarify, those cutting their braces do not have a serpentine setup.
Old Jun 3, 2004 | 09:28 AM
jgifford's Avatar
Car: 1986 Z28
Good point, I didn't even think to look at his setup.
To cut it, I used a cutting disc on our air compressor, the used a bench grinder to smooth it out so it didn't look like a hack job.
Old Jun 3, 2004 | 12:10 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys!!
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
