"Touching up" ceramic coating?
Old Jun 7, 2004 | 12:04 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Can ceramic coating be touched up? The AIR tubes on one my headers have broken. I want to cut the tubes off entirely but I don't want the headers to look like crap after they're gone. Does anyone know if the coating can be touched up once the holes have welded shut?
Old Jun 7, 2004 | 09:40 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Anybody?
Old Jun 8, 2004 | 07:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't think it can be "touched up". There is a special process used to put it on, unlike paint, so you'd likely have to have it redone to cover everything.
Old Jun 8, 2004 | 09:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's not really all that special but, putting cermakrome (ceramic coating I use) over itself is similar to what happens when you use laquer touchup paint on an enamel finish
The overlapped areas will cause lifting and flaking of the prior finish, at least... that's what happend to me on an area I missed when recoating my old edelbrocks. "High-temp" paint will pretty much fry it off too during the cure stage (found this out from curiousity).
It may be possible, if you (or whoever) are meticulous enough to be able to get (tape) a sharp line around the spot to be fixed then, blast and lightly touch it up. I've never tried but, I'd be curious to see if it can be done. Granted, it would probably still show the where the repair was done but, at leat it wouldn't be a big spot of rust. TPI383 would likely be one to give you a better answer. Just my opinion though..
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
