All Piont bullentin (APB) on Headers
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I'm looking for a set of headers that will meet the criteria for my Combo.
Here is what I plan on using but need to find a set of headers that meet my needs. If you have any info for thirdgen camaro that meet the following specs let me know.
I got this recommendation fro a header designer who feels these will maximize my combo for the street and Rpm.
409 cid and 1 5/8" headers "Tune-In" between
3500 to 5500 rpm
The best primary lengths will be either 23" inches or
46" inches
The best Collector dia = 3.000" inches OD
the best Collector lengths will be =
12.5",25.0",50.0", and 100.0" long
the worst Collector Lengths will be;
18.8", 37.5" , and 75.0" inches
2 1/2" exhaust is about right because exhaust gases
cool as they travel further down the pipes
3500 to 5500 rpm
46" inches
Can some give me the primary length and collector length for the
hooker 2460 and Hedman 68460:
Dave
Dave
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Jegs lists the hooker 2460 as 1 5/8 x 15 primaries with a 3 o.d collector that is 4 in long, it is a shory header. the hedman 68460 is a 1 5/8 primary with 3in o.d collector. all they say about the length is that it is a full lenght header that rquires dual exhaust
Transmission: 4L80E/4L80E
The 2460's are not equal-length headers. They may be 15" from top of flange to bottom of collector, but the primaries are longer and shorter than that.
The 68460's are long-tubes, approximately 30" primaries (but again, not equal-length).
1-5/8" primaries are "torque" size for a 409 cid engine. 1-3/4" would be better for power. Of course, you didn't give any details of the rest of the build or intended use, so it's a little difficult to make a real recommendation.
There are some pretty quick 454's and 455's out there running on 2-1/2" dual exhaust.
I have already got the recommendation that I needed. Now i'm looking for the headers/part# that fit the recommendation with the dimension listed above in the form of 1 5/8 for a 84 Camaro.
I'll go one step farther: No commercially available headers for 3rd gens meet the specs you talk about above. If you want such headers, you are going to have to fabricate them yourself or have them custom fabricated.
Out of the two, which header come close to meeting those specs:
The 2460 or 68460
The 2460 or 68460
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
after reading your engines description i believe your car would perform better with long tube headers and a true dual exhaust. altho it will be much easier and you will have more ground clearance with shorty headers and a single exhaust.i would think a 3 1/2 single exhaust would work good for your application. i persnally run the hooker super comps on my car with the hedman shorties i originally put on it just killed my power output. the super comps are a night and day differance
redformula88
Oct 14, 2015 06:08 PM
