Is this a bad thing to do?
Old Jul 11, 2004 | 02:04 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Is it safe to remove the Smog/A.I.R system?
My question is will this hurt anything? Is this a bad thing to do?
Old Jul 11, 2004 | 03:38 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Yes its bad. You could burn a valve.
Old Jul 11, 2004 | 04:32 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
impossible to burn a valve with those unplugged. essentially it's just an exhaust leak. you will find a lot of carbon buildup occure on your hood though. it probably has a little "tick" to it now too which is very annoying to me. i would think that it wouldn't sound all that good. i would plug them up just for cleanliness sake.
Old Jul 11, 2004 | 05:02 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
How do you think you burn valves? Burnt valves occur when you have an exhaust leak that is to close to the cylinder head. I originally thought he had no air tubes at all, leaving several huge exhaust leaks right by the exhaust valves. Now that i reread i see he still actually has the airtubes. So he probobly wont burn a valve, but its still not a good idea.
Old Jul 11, 2004 | 05:42 PM
Marc 85Z28's Avatar
84firebird383 - what you've heard is at least overexaggerated, or just a myth. You'd need a huge leak, like no exhaust at all. Just open ports. And on top of that, you'd also need a cam with a lot of overlap to create a lot of reversion. Then you'd have to run it for a long time.
A small exhaust leak near the head WILL NOT cause a burned valve. If that were the case, most of us (and all "hot rodders") would be pulling heads and replacing valves on a regular basis. Exhaust leaks at the flange are quite common. Burnt valves are not.
Old Jul 11, 2004 | 06:16 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Yes. I agree, but like i said before I originally thought he had 8 open holes in his exhaust manifolds right by the exhaust ports. That could be enough to burn a valve. I personally had the bad luck of blowing out a large portion of header gasket at the track. I ran it anyway despite the huge leak. When i had a valve job later my engine builder could tell.None of it pertains to johnjm22 because his leak isnt what i thought it was at first. I still say he should just plug them up.
xxx3man`
Sep 23, 2015 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
Bob88GTA
Aug 18, 2015 03:31 PM
