Milling flange for strightness?
Old Jul 26, 2004 | 10:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
For the life of me I cant get my SLP 1 3/4 to seal. I've used Felpros and now I'm using hte percys dead soft (expensive as he11) gaskets and I keep seeing blowby. No matter how tight these are they still leak. I'm wondering if they are warped or something. If so , even though they are in 3 seperate pieces, can a maching shop mill it all across and make it true?
Old Jul 26, 2004 | 10:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It may be easier to tweak the primaries by bending them a little bit. The SLP's are prone to this since there isn't a uniform flange across the primaries.
Old Jul 27, 2004 | 11:14 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Been there, done that. Take them to a machine shop that has a flat-wide sander and see what they can do, that's what I did.
Take off the headers and put them flat flange down on a flat surface, like a table, and try to put some feeler guages under different spots. You could see where mine were warped, and they wouldn't even bolt up to the heads because they move/shrink a little when they cool down. Common problem.
Old Jul 27, 2004 | 11:16 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Do not bend the tubes, I broke the weld between 2 tubes down inside the collector trying to bend the outer tube to get it straight and had to have it welded to fix it, get it machined flat with a belt sander or something.
Old Aug 6, 2004 | 03:47 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
Use high temp silicone. it is way cheaper than any gasket. A seven dollar tube will last you for years. If you have a bad warped spot, you can put the stuff on both sides of the gasket or even double up gaskets in a 'silicone sandwich'. I had to do that on the 4-6 flange and it never leaks. I haven't had to tough it all year, where I was tightning bolts and fixing gaskets all the time before.
It works mint for collector gaskets, too.
Rousseau92maro
Feb 1, 2016 05:12 PM
no green
Jan 9, 2016 09:22 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Eric-86sc
Sep 22, 2015 08:25 PM
