does edlebrock tes fit to aluminum vette heads?
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
will the edlelbrock tes headers for an f-body fit the aluminum vette heads out of a 88 corvette??????? getting good deal on the vette heads and i purchased the headers a while ago. so im just trying to see if they would fit fine with the heads??
thanx
dave
thanx
dave
hey thanx now will i be able to use the exhaust manifold gaskets with the headers fine or do i need to get header gaskets????? im going to be getting a head gasket set and manifold gaskets come with the set..so will i be able to get away with those for a little bit?
thanx
thanx
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Every production SBC head has the same exhaust port/bolt pattern. Yes it will work.
Car: 84 Z28
Axle/Gears: 3.73 Torsen
they all have the same bolt pattern, but the Vette heads have angled plugs and raised exhaust ports which could potentially cause issues with header fitment.
88GTAbandit - you should be able use the exhaust gaskets that you have. I've used both production Vette exhaust manifold gaskets and Mr. Gasket #150B header gaskets with equal success.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
