Welding questions
Old Sep 5, 2004 | 07:13 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Welding questions
Not sure where to post this so I suppose I'll do it here since this is were the information will be used.
The mount has pulled off my tip and I was wondering if I could weld it back on using one of those propane tanks you put a tip on, torch bascilly. I was also wondering if I could use that to weld my exhaust together when I change it after the muffler to come out the sides instead of the rear.
Old Sep 5, 2004 | 07:34 PM
purdyred89's Avatar
Car: 89 RS
Engine: 2.8L v6
Transmission: 5-speed
if you do not know how to weld then dont even try it. i would recommend not welding on anytihng that you like for at least a few years of practice. you could just go to a muffler shop like meineke or something they should do it for fairly cheap.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
redmaroz
Aug 16, 2015 11:40 PM
