universal x-pipe system with hooker 2210?
Old Sep 9, 2004 | 03:43 PM
daddy33's Avatar
Car: '85 Camaro
I just got my 383 all fired up and now need to put on an exhaust system and wanted to know if this universal x-pipe system from summit will work fine and if anyone has used it. It is part number SUM-642130 and hedman has the same thing P/N HED-18830. (I believe they are the same its just Hedman cost more).
Anyways i just wanted to know if anyone has tried using this setup with the hooker super comp 2210 and if so if u had any problems? Im looking and using this setup and get a pair of dynomax bullets and have it dump somewhere near the axle. If you have pics available it would be great. I looked around and i mostly seen h-pipe systems but was told the x-pipe is a better route to go. I appreciate the help....
Old Sep 10, 2004 | 10:55 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Xpipe is the best route, you are correct..
I have not seen anybody use the X or H pipes out of the summit mags. Feel like being a ginni-pig for all of us? Chances are it will not work, maybe if you do some slight mods to it it will work out for you but be prepared to put alittle time into it.. Your best bet is to have it custom done, buy your mufflers, take them to a good shop and have them do it up.. good luck with what you decide..
Mike
Old Sep 11, 2004 | 04:43 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I've got the universal one from summit on my car. Its actually a very nice piece. You can't beat the price either.
Old Sep 12, 2004 | 09:48 PM
SnkSknrZ28's Avatar
Any pictures 1FastZ????
Old Sep 13, 2004 | 07:08 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Just built a new PC so I will look around to see if I can find some for ya. I haven't put any pics back on this new one yet.
Old Sep 14, 2004 | 03:57 PM
daddy33's Avatar
Car: '85 Camaro
hey 1fastZ, when or if you do get those pics i would like to see them also. In your sig is seems like i'll be going somewhat with the same setup as you. Im going to get the x-pipe from summit and dump a pair of dynomax bullets before the axle.
RaverRacerX
Mar 17, 2026 01:49 AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
