Did Jet-hot send me the wrong headers?
I just got my heman shorties from Jet-Hot, and I think that I got the wrong part. The Y-pipe doesn't look right at all. I can barely make out a part number stamped on the flanges that looks like 69481 (for a gm truck) instead of 68481. Can someone confirm that I should only have an O2 bung on the drivers side? If anyone has pics of what the 68481's should look like that would help too. Thanks.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Car specs would help...
But generally speaking the 3rd gen f-bodies do only have one O2 sensor in the drivers side manifold/header...
Car: 87' IROC
Originally posted by Chris's 85z
Look the same as mine them are right!
Thanks guys. I was already pretty sure, but that is definitly a different Y-pipe. KagA152, did you have the AIR tubes removed, or did you go with the non-smog headers?
Oh yeah, it's an '86 LG4 Firebird.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i bought them off a friend, so im not sure, but judging by the weld job on the o2 bung and y pipe joint, im going to say they didnt have air tubes cause theyre still nice and smooth up there
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
The Headmans don't have an 02 bung. you'll have to weld one in. I put mine in the short piece of the ypipe on the drivers side. That way the coating on the headers wont rust from the grinding/welding. Only the small piece of the y pipe will. Once you scratch the coating, moisture gets under there and rusts the whole piece.
TheTraut88
Sep 7, 2015 05:22 PM
