new dual exhaust pics that i promised
Old Oct 13, 2004 | 04:58 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i used the summit mufflers part number 633222. i absolutely love the sound. comparable sound to flowmaster. i am very impressed. ground clearance seems to be pretty good too. don't mind the miss-matched wheels, i am painting the rears to match the fronts before the end of the week (hopefully). remember, i have 275/60/15 tires, so my clearance is a little better than most. i hope to have the system welded up within the week also (was waiting for my dad to return home with the welder)
close up of the ground clearance
Old Oct 13, 2004 | 08:00 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Now just get yourself some high temp black paint and you'll never know it's there!! Looks good.
Old Oct 13, 2004 | 10:21 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Do you have an H-pipe or anything? Is there anyway you could get it up on jack stands and take a photo of the whole thing from under the car. I'm interested in doing something along the lines of that and just want to see what it looks like, placement wise, under the car. Great job.
Old Oct 13, 2004 | 10:38 PM
mw66nova's Avatar
Engine: 7.0L
yes, it has an h-pipe and i will get it up and jacks in the next few days to weld it up and i will get some pics of it then.
for some really strange reason, i actually like that you can see it...
Old Oct 13, 2004 | 11:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i never thought to use high temp black paint. how high of a temp should it be rated for? i know what i'm doing this winter now with my exhaust. flat black high temp all the way.
Old Oct 14, 2004 | 06:33 AM
IHI's Avatar
IHI
I just got some of that ceramic high temp header paint. Let the car run for awhile to get the pipes good and warm and sprayed the heck out of it.
Just my personal opinion but exhaust should be heard not seen and since we got the short end on our cars with ground clearance, painting it helps it blend into the shadows.
Old Nov 13, 2004 | 01:52 PM
mw66nova's Avatar
Engine: 7.0L
welded it up today (my 3rd welding job ever, don't laugh at my sloppy welds...)
Old Nov 13, 2004 | 04:04 PM
IHI's Avatar
IHI
LOL, not bad for your 3rd time. Nice layout underneath, looks clean. Next time for better welds touch up the areas that are old with a grinder to get into some "fresh" metal as any oil or garbage screw the welds up faster than you can blink, after it's touched up go over the metal with a rag and some break clean to get any remaining residue off-this helps a bunch especailly on exhaust peices.
Turn the heat up a little more also, the welds dont look to have very good penetration. Beings how it's exhaust it wont matter since it's basically just holding peices together. Practice practice practice Gotta buddy that always has me weld for him and the past 2 yrs I've been telling him to start it out and I'll see how he's doing. Getting better but still not "pretty" welds.
Anyways, nice work.
Old Nov 13, 2004 | 04:17 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Very nice!
..And it just occured to me how I can get past the issues with jacking up the front right side of the car without some fancy jack placement..
Old Nov 13, 2004 | 05:12 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I started moving the mig head in a "c" rotation...Looks like a roll of dimes :-D ((((((((((((((((((
Old Jan 23, 2005 | 11:52 PM
sickstrings84's Avatar
Car: 2003 Chevy Cavalier LS
Engine: 2.2 I4 ECOTEC, crane cam, FAST piggyback ECU
Transmission: 5 spd
Looks pretty sweet man. But I got one question. Are thos mufflers underneath of the rear diff?? or is it just the picture
Tim:rockon:
Old Jan 24, 2005 | 12:02 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
how loud is it without cats. where they the 20.00 mufflers or the 40.00 ones
jon
Old Jan 24, 2005 | 12:54 AM
nick418's Avatar
Engine: L98, Hemi 6.2
looks good, i perfer going all the way...
Old Feb 27, 2005 | 03:44 AM
83 Crossfire TA's Avatar
Not bad… I like how you routed it around the tranny/tranny crossmember. That probably left you with about as much ground clearance as you’re going to get on that kind of setup.
FWIW, next time, try turning the turndowns inward slightly rather then outward. Usually that kills some of the droning inside the car by canceling some of it out, so basically you’re left with a nice, low base note. My brother’s car actually ended up slightly quieter inside (it basically lost the interior droaning) going from 2.5” full length duals to 3” turndowns, but it gained a really cool, ground pounding base note (standing next to it idling it feels like the ground is actually thumping with the car).
Heh, something like this :
Old Feb 27, 2005 | 09:34 AM
mw66nova's Avatar
Engine: 7.0L
thanks mark,
i thought of doing this as i have known about that trick for a few years. but for some reason, i like the way this sounds better. strange, i know. but thanks none the less. and thanks for the compliments on my welds, even though they are **** poor. i am starting a welding certification class next month, i should be certified in TIG welding by Christmas.
Old Feb 27, 2005 | 10:19 AM
klumb15's Avatar
looks awesome...any sounds clips? which mufflers do you have? is that dual 3's or dual 2.5's?
Old Feb 27, 2005 | 02:20 PM
mw66nova's Avatar
Engine: 7.0L
it's dual 2.5's, i don't have any sound clips but imagine a sbc with a cam and flowmaster and that's pretty much what it sounds like, but they aren't flowmasters, they are summit racing "welded chambered" mufflers. summit p/n 633222. they were 39.99 a piece, but i think they are like 41.99 or something now, still really cheap and they work really well. they're like a 3 chamber muffler so they aren't really loud or droning like my moroso spiral mufflers used to be. i really am pleased, still 5 months after i put it on the car.
Old Feb 27, 2005 | 03:16 PM
MIG is not exactly easy to get nice welds on with thin guage exhaust tubing. I can usually get an even bead, but I really tell most people that if you have something that does not leak on 16 or especially 18ga tubing then you did OK.
Personally, I wouldn’t waste my time tigging exhaust unless it was a showcar or something so delicate that you really couldn’t do it with a MIG.
Old Feb 27, 2005 | 04:12 PM
mw66nova's Avatar
Engine: 7.0L
well, MIG is a prerequeset for TIG, so i will be able to do that too
Old Feb 27, 2005 | 05:37 PM
klumb15's Avatar
that would majorly suck TIG welding a complete exhaust...who cares abotu the welds anyways they are under the car, all that matters is if they seal it....the reason that bead in the picture looks so good is because its on really thick gauge metal (exhaust flange)...but if you can weld them, and they stick together, thats good enough
Old Feb 27, 2005 | 05:51 PM
That is exactly why it looks like that, and I never made out that there was any other reason. My friend that owns the car said “do something cool with the weld” and I said “sure, how’s this? You could tell everyone that you spent the $$$ and had this thing custom TIGed”
Take a look at the dynomax setup that I posted in the dynomax exhaust thread, the welds are almost as nice and maybe slightly cleaner on the 18 and 16ga exhaust tube, minus the pretty pattern. FWIW, if I remember right the above pic was done with flux core (for those of you that keep saying that you can’t make nice welds with flux core).
Old Feb 27, 2005 | 06:07 PM
klumb15's Avatar
flux core? is that stick welding? I can lay a pretty damn nice bead with stick welding, and i'm only 18!!!
Old Feb 28, 2005 | 12:14 AM
Flux core is wire feed without sheilding gas.
Old Feb 28, 2005 | 07:42 AM
klumb15's Avatar
ohh..i've done that before on accident...haha, forgot to turn on the gas before i started welding....the weld gets a bunch of pinholes in it thats for sure
Old Mar 1, 2005 | 12:51 AM
jocww's Avatar
im good a tigging id rather tig than mig any day
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
