A/C removal?
Old Oct 17, 2004 | 07:23 PM
jdalla's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
A/C removal?
Does anyone have any instuctions and pics of what the engine bay looks like without A/C stuff. thanks
Old Oct 17, 2004 | 09:20 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I have some instructions, but no pics.
First off, the only thing you will need to buy is an AC delete pulley. It bolts right in to the stock location (where the AC compressor was). You can get it from your local GM dealership or a place such as www.gmpartsdirect.com . The part number for it is 10055890. If you want, you can also buy a non-AC heater box (big black box on the passenger side firewall), but it's not required, and they're also kind of hard to find now.
The first thing you should do is get the system discharged from a shop. It is illegal to vent refrigerant into the atmosphere .
Now for the parts removal. It's pretty simple. The first thing to do would do is remove the lines. Then take the belt off and remove the compressor and install the delete pulley and put the belt back on. Then unbolt the radiator, slid it back a little, and remove the condensor. Then remove the receiver/drier (the metal round can-looking device). Now cap off the the two big lines that lead into the blower unit/heater box (the big black box on the passenger side firewall) that lead to the evaporator, install the non-AC heater box, or just make a custom block-off plate.
I can go into for detail if necessary, if you need it. Just post or PM me.
Old Oct 18, 2004 | 03:13 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I have a pic, when I get home I'll see if I can post one for ya.
Old Oct 21, 2004 | 09:07 PM
CraZ-28's Avatar
Car: 1991 Z-28
Opps, spaced out and forgot. My bad. Here is a pic I took right after I took it out.
Attached Thumbnails A/C removal?-picture-013.jpg
Old Oct 21, 2004 | 09:08 PM
CraZ-28's Avatar
Car: 1991 Z-28
Oh yeah, mods you may want to move this to a different forum.
Old Nov 1, 2004 | 04:54 PM
jdalla's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
yeah sorry about that...wasnt thinking when i wrote it.
Old Nov 9, 2004 | 07:38 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
heres mine
Attached Thumbnails A/C removal?-951_installed_big.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
