percy's "seal-4-good" gaskets (and studs?)
Old Oct 20, 2004 | 08:57 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
got my percy's gaskets today and they sure seem to be pretty thin on the outer edges of them... i hear they're like one of the best ones out there, so i guess not too many problems are being had with them...
along with the gaskets, i got my stage 8 bolts, but where there used to be studs on the manifolds, what are you guys using to secure the a/c and alt? if studs, don't you have to use a diff kind?
KAM
Old Oct 20, 2004 | 09:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: percy's "seal-4-good" gaskets (and studs?)
KAM
You can use the stock studs and just washers or anything you may need to fab up to get the braces to work. I use the stage 8 bolts and did not retain the braces. So far so good. I am sure I am risking breaking something but I don't really care.
Old Oct 22, 2004 | 11:44 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I deleted the braces all together and I have no problems. Looks like GM went for the overkill in securing the accesories. Also, you are making an excellent choice with Percy's. One of the best out there.
Old Oct 22, 2004 | 06:38 PM
Car: '91 Z28
Axle/Gears: 323's
well i was finally able to dummy hang the headers on the eng today, but the studs that came off my original exhaust are gonna be too short anyways... thanks, SLP... made the "stud collars" or whatever they are too long so the studs will be too short. so much for being able to use all the stage 8 bolts i bought, too... oh well, i'll figure it all out and get it together one day.
KAM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
