Dual Cat option
Old Oct 28, 2004 | 05:55 PM
KiLLJ0Y
Guest
Posts: n/a
Dual Cat option
is the Dual Cat option on TPI cars worth more HP that a 3" system?
i converted my 5.0 TBI to 350 TPI and went with a 3" system from the header collector all the way back. i heard the dual Cat gives 20 hp more than a full 3" system. is this true?
also did all 350 TPI's have the dual cats in 92? im trying to stay smog legal here in CA
Old Oct 28, 2004 | 06:32 PM
Parrydise7's Avatar
You just opened a can of worms! Well, what the heck. You might want to do a search because this comes up all the time.
Now, here's what's going to happen. Somebody's going to pull out their calculator and say, yes 2 2.5" tubes are better than one 3" because... yada yada yada. And then somebody else is going to... well, I think you get the idea how it goes.
Why don't you ask DynoDon what he thinks? Or, maybe he'll just read this and answer it on his own.
Old Oct 29, 2004 | 10:29 AM
KiLLJ0Y
Guest
Posts: n/a
well i was more concerned about being smog legal. if all 92 350 TPI's came with a dual cat or not. i dont want to get busted by the smog police when the time comes up in Feb.
the added HP(if any) is just a plus
Old Oct 29, 2004 | 10:41 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Ok, here's the deal.....our cars came with TPI (f-bodies) so it doesn't matter if you change from TBI or carb it will pass without going to a referee. Some also came with dual cats, so same thing applys, if challenged just say it's a '92 motor even if it is an '88 car because you can change to a later engine with no problems.
They didn't come with G92 until '89 (dual cat part). Besides most don't know the difference.
Old Oct 29, 2004 | 11:12 AM
KiLLJ0Y
Guest
Posts: n/a
awesome,
still need to get a new cat since this one is wasted. hey Don i have an idea on the cold start to my car. i'll send you a PM about it
Old Oct 29, 2004 | 11:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A really **** inspektor can determine that in '92 (and since your chassis is a '92, you have to meet at least that standard), a single-cat car would have a 2-1/4" cat, and a dual-cat car would have two 2-1/4" cats. If you have a single 3" cat on there, it could be grounds for rejection, because the factory didn't put a single 3" cat on our cars in the 1992 model year.
mud runner
Nov 2, 2015 07:30 PM
customblackbird
Oct 1, 2015 04:30 PM
jer4251
Sep 16, 2015 11:29 AM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
