Just installed Mufflex
Old Nov 16, 2004 | 11:47 PM
IROCFAST's Avatar
Hey fella's, just got done installing the 3.5" mufflex system with a spintech muffler and single outlet. All I can say about the sound is WOW! We used the dual cat system, took 3" pipes off the FL headers and used a single 4" pipe to merge them then necked it down to the 3.5" I know some of you may think that using the 4" Y-pipe may be useless, but it is all in the name of velocity and flow. I previously had dual 3" under it and I really think it picked up some low end and didn't lose any off the top. This thing sounds great, this is the 7th exhaust system on the car and by far the best sounding! I also channeled the crossmember to keep everything tucked up close and retain max ground clearance.
Old Nov 16, 2004 | 11:51 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i think spintech has the best sounding mufflers, deff whats goin on my car this winter.
btw, where is new athens?
Old Nov 16, 2004 | 11:57 PM
IROCFAST's Avatar
Do you know where belleville is? That is where I am getting ready to move. I am about 25 miles east of STL, MO right now.
Old Nov 17, 2004 | 01:26 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
where do u buy spintechs?? I'm lookin to take off my 80 flowmaster and put sumitn in its place cause i have no tailpips so it down;t matter
Old Nov 17, 2004 | 10:33 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
SPINTECH ALLL THE WAY......i just put spintech on my car bout a month ago....i used to have flowmaster and hooker on it...got comments on them every now and then......now i get comments everywhere with my spintech it sounds mean.....ohh and i picked up a good bit of low end....spintech rcoks....ohh and the mufflers are bullet proof....nice and shinny sittin on the car and no signs of any rust...especially with the rainy weather here in ohio....i suggest spintech.....go to spintechmufflers.com call them and order it....the only vendors are in cali...it may take a lil to get tho....they make ur muffler when u order it...now thats quality....but ya go spintech
Old Nov 17, 2004 | 12:10 PM
IROCFAST's Avatar
http://www.spintechmufflers.com If you do not find what you want, he will make it for you for not a whole lot more.
Old Nov 17, 2004 | 12:54 PM
Car: 89 Formula
Engine: Carbed 5.7
wutch one are you guys runing? the prostreet??
Old Nov 17, 2004 | 01:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah, are you guys running the stock replacement fit crossflow style? I believe its the 343sc or 344sc split case thing?
seen mufflex 4inch system before but it was single inlet outlet muffler like those race mufflers. was loud and deep!
Old Nov 17, 2004 | 02:55 PM
IROCFAST's Avatar
sportsman here, if you wanted the daul out you would have to buy a sportsman split case.
Old Nov 17, 2004 | 03:11 PM
christian's Avatar
Any Pics?
Old Nov 18, 2004 | 10:33 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
ya im running the sportsman split case....sounds mean as hell...ill be goin to spintech for all my exhaust needs
Old Nov 18, 2004 | 07:49 PM
Camaro_nut's Avatar
Just to throw in my 2 cents....
I am running the Mufflex 3.5" exhaust system with
the Spintech muffler. I get nothing but compliments
with the sound. Way better than Flowcrapper! Those
systems rot out all the time.
Old Nov 19, 2004 | 10:36 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
This is my brothers 383 super ramed, 91 camaro, it has a 4 in. mufflex with hooker long tubes. He has the race series flowmaster. It sounds great. Most people think it is a big block when they hear it. And it is not rusting at all. It over two years old.
Attached Thumbnails Just installed Mufflex-rsd-pic-1.48-60
Old Nov 19, 2004 | 12:08 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
my mufflex 4in single outlet is about 5 yrs old. i have had no problems with it and no one ever confuses my car for someone else's! it wieghs lik 65lbs, but i love the deep rumble. mine has a flowmaster muffler. ive heard the spintechs, and ive heard an edelbrock, but they dont sound so much differnt. andi couldnt dream of taking a $140 muffler off my car! what the hell would i do with it then?
Old Nov 21, 2004 | 05:28 PM
Marc 85Z28's Avatar
IMO the Spintech on Mufflex's 4" system sounded horrible, on my application anyway. After spending the extra few hundred to get the dual out Spintech system, I traded for a used Mufflex Flowmaster single in/out and tailpipe. Sounds like it should now. Not to mention the Spintech was nearly 15lbs heavier!
Old Nov 21, 2004 | 06:48 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
hey TurboedTPI, I saw that car at RSD, man is it clean Do you have the specs on the motor, or is a secret?
Old Nov 22, 2004 | 07:54 AM
IROCFAST's Avatar
I am just the opposite, I had a flowmaster and it sounded awful, it got extremely tinny sounding anything above 3k rpm, the spintech sounds awesome at all RPM's. My spintech did not seem to weigh that much more.
Old Nov 22, 2004 | 09:05 AM
TurboedTPI's Avatar
Car: 92 Formula 350
It's my brothers car. Im not sure if he wants me to post every thing. But I'll tell u it is a 383 with a superram, in the 11's. Did you run your car that night at rsd? Your car looks familar. Did you have slicks on the back with black wheels? I think i remeber a red third gen with your wheels on the front and black ones on the back.
Old Dec 22, 2004 | 10:12 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
bawaaa,,,...
idle
Old Dec 22, 2004 | 03:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
do you think that going from longtubes and true duals to shorties and custom y-pipe and a single 3.5" will slow the car down?
Old Dec 22, 2004 | 06:07 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Funny, I just pulled my mufflex 4" system off today! I think im going to throw it away.............j/k!
Old Dec 23, 2004 | 06:37 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I'm not doggin on ya, but I dont think with your current motor you'll lose anything. Crazy as it sounds i think it might actually help some. Keep your current set-up stored somewhere though so when you step up into a bigger mill you have the system to back it up. If nothing else, skip the 2.25" and go 2.5" pipes. That will support a healty 355 also.
I used to run the Heddman LT into true dual 2.5" pipes and it picked up-cant remember but it was better than the factory manifolds and single exhaust.
Old Dec 23, 2004 | 07:02 PM
mw66nova's Avatar
Engine: 7.0L
well, i have 2.5" not 2.25", but i think i will just keep it like it is right now, i just don't have the money to do anything else right now. i need interior next.
anyone got grey interior stuff?
Old Dec 23, 2004 | 07:16 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
What do you need? PM me. Don't have much left, but a few things.
Old Dec 23, 2004 | 07:17 PM
IHI's Avatar
IHI
I've got a cloth graphite (kinda dark grey )98 firebird back seat that's not doing me any good
Old Dec 23, 2004 | 08:09 PM
mw66nova's Avatar
Engine: 7.0L
front seats
headliner for a hardtop
sailpanels
sunvisors
doorpanels
and the hatch motor cover
i got a very limited amount of cash, so the cheaper the better, ya know.
Old Dec 25, 2004 | 03:37 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
that sound clip sounded awesome
Old Jan 2, 2005 | 03:35 PM
REALPOWER's Avatar
Transmission: Th350
Heres what I pulled. Complete with a 4" cat. It is for sale. How much should I be asking for it? I also have SLP headers for it.
Old Jan 2, 2005 | 03:36 PM
REALPOWER's Avatar
Transmission: Th350
and another
Old Jan 2, 2005 | 09:19 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
4" y pipe and 3.5" exhuast? strange. never heard of such a large y pipe. that thing must scrape everywhere.
pics?
Old Jan 2, 2005 | 09:58 PM
IROCFAST's Avatar
I channeled the crossmember so it is actually tucked up quite nice. It will be a while for pics, it is back apart....again!
Old Jan 3, 2005 | 10:44 AM
REALPOWER's Avatar
Transmission: Th350
Who wants mufflex?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Jan 3, 2005 | 05:46 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
:nono: Keep it up Realpower
Old Jan 3, 2005 | 05:57 PM
REALPOWER's Avatar
Transmission: Th350
Im sure someone out there would find those links helpful in their exhaust pursuit. I am also sure that you need to let the moderators lock or change my threads. Your nose can't get any more brown.
Old Jan 12, 2005 | 10:45 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
from what I head on spintech's website, I love em! I got an LO3 now with no cat and flowcrapper, and Im still blueprintin out the 383 for it (just got the block from the machine shop today )
But one big difference I notice (other than their motor and mine) is it doesnt have that crappy sounding backpressure when you let off the throttle at high RPMs, I think u guys know what Im talkin about. I didnt hear anything like that on any of the SBC they had on their. That right there is a big selling point for me! it sounded smooth and deep all the way up and down the RPM range.
Old Jan 12, 2005 | 10:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
the sound of the spintech is un-matched. no one could reproduce that sound. big block at idle and it was very crisp, but not too raspy while on the gas.... but the interior noise! it drove me to swap the muffler.
Old Jan 15, 2005 | 02:50 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
One question where did you find a cat that big!? i would like to know thatnks.
Old Jan 16, 2005 | 12:04 AM
spills's Avatar
Car: 89 RS
Catco wud be the first place Id look. Im sure they make 4", considering newer diesel and BB trucks are starting to come out with aftermarket performance parts. Might have to go thru them direct though, but who knows, maybe jegs or summit might have one.
Old Jan 16, 2005 | 12:12 AM
IROCFAST's Avatar
Randon Tech makes one
Old Jan 17, 2005 | 02:05 PM
David @ Thunder's Avatar
Supporting Vendor
Guys, don't get too rapped up on the SpinTech's. We've done a lot of dyno testing on exhausts. Unfortunately Spintech and Flowmaster are the two worst mufflers to use on the f-body applications. Unfortunately, this is the only two choices Mufflex has to offer with their system. My personal car is a 91 Camaro using the Mufflex 3.5" single tail system. I switched from the Spintech to a Hooker Aerochamber and picked up just over 10rwhp. I will say the idle was awesome sounding on the Spintech, but overall the sound is much better plus more power with the Hooker. The Mufflex will need to be modified slightly to fit the Hooker but we do keep them in stock. Unfortunately, Hooker doesn't have any in 4" size.
Old Jan 17, 2005 | 09:36 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
I've been running FLO-PRO's V-force on my GTA. Basically its a much better copy of a Flowmaster 40. Flows much better and sounds better too. I have never heard an F-body sound like mine.
Old Jan 17, 2005 | 09:53 PM
  #42
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
spintech and flows dont flow, LOL
ive personally seen 10 WHEEL HP loss from a head and cam ls1 car
flowaster vs cutout. 15 wheel hp
dynomax vs cutout, only picked up 5 wheel hp.
ive seen 20 on a built Lt1 car. by changing the slowdisaster to a dynomax. :hail:
Old Jan 17, 2005 | 10:35 PM
  #43
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Dynomax Ultraflow Weldeds are the best flowing muffler on the market. I Just don't like how they sound.
Old Jan 18, 2005 | 05:29 PM
  #44
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
lil raspy like a borla, with a hint of a flowmaster sound. very mute. they arent crazy loud on the inside and the exterior noise aint bad either. i run a 3" offset/3" center.... then a bullet muffler inline as well. i have a pretty stout small block and its very tame for its power.
Old Jan 19, 2005 | 01:51 PM
  #45
TurboedTPI's Avatar
Car: 92 Formula 350
Sorry, but i disagree, my buddy had a 94 Z28 with one of these. It sounded ok but the muffler started to rust in 2 yrs. And how could it be a better copy of a flowmaster, if its a copy?
Old Jan 19, 2005 | 05:38 PM
  #46
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Better copy meaning that there are alot of copies of Flowmasters floating around. Its a better copy than the other copies.
Old Jan 19, 2005 | 11:10 PM
  #47
spills's Avatar
Car: 89 RS
what do u guys think about the aerochambers? sound and performance wise? I know a guy at my works got a BUILT all out drag 77 chevy and he runs those, but its kinda hard to compare how they sound on his blown nitro'd BB to my stroker SB
Old Jan 19, 2005 | 11:32 PM
  #48
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
hookers are really quiet at idle, and they really open up when you step on it. great flowing mufflers as well. i do think ive seen some CFM ratings where the dynomax flows more... just dont get an offset/offset muffler, it kills flow.
center/center
center/offset
only way to go.
Old Jan 20, 2005 | 08:24 AM
  #49
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
If you run the pipes like the factory did you have to go offset/center.
Old Jan 20, 2005 | 11:07 AM
  #50
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I decided on Spintech after listening to many different soundclips.
When i ordered the 3" catback the guy at spintech said they didnt have the curved piece of pipe that goes over the rear axle
I was like wtf, Anyway, the guy that installed it said he had a hell of a time getting it on there, as some of the curves in the pipe didnt seem right. Its slightly crooked in the back right now, and pi$$es me off somewhat. I need to have it adjusted to fit right.
anyway the sound is awesome. very low tone at idle...almost quiet. But when you get on it at WOT, the pitch gets higher and it sounds very mean. JUst wish i had more HP now to really make it do its thing.
