Cat plugged, fixed, now what?
Old Nov 18, 2004 | 12:20 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
OK I've had an intermittent problem with my cats getting plugged, it finally backing up until it all blew out for a good 6 months. Don't ask me why I didn't do anything until now, it's a long story.
I took a hacksaw to the pipes before and after the cat, and got it out. I threw that out. Now I have a huge hole in the exhaust where the cat used to be. I rigged it because I had to be at work in an hour.
I used a 18 inch long piece of straight pipe, an adaptor and this flexible pipe that (MOSTLY) worked. Now its very loud of course, but it works great, and no more plugged cat.
6 months later driving around like this, I'm sick of it. Every so often the rig comes off and I gotta stop and put it back on, the clamps don't exactly get it tight enough, and so on.
My friend said I should put a cherry bomb in that space. Is that around the right size for it? I am not spending any money on something that will plug up later on. I don't want to hear about backpressure, or emissions. When they bring that back in south florida I'll worry till then, I'm killin bambi.
Thanks in advance.
Old Nov 30, 2004 | 11:50 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Well, I would not want to give you any illegal advice but from what I've seen, some people simply gut the cat (beat the internals out) and stick it back in. Free flowing cat.
Once again, it might be illegal in some states and I am NOT encouraging you to do that. Just stating what others have done.
Lou
Old Nov 30, 2004 | 02:21 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Just get someone to weld a peice of pipe to connect the exhaust for you. I'm sure it wouldn't cost more than $45 for such a simple job.
We don't have inspections in Florida, so that's not a big deal. I wouldn't recommend gutting the cat though. I've read that removing the internals just makes more turbulence in the exhaust rather than making it more free flowing.
onefreakz
May 14, 2018 12:15 PM
Bert87
Aug 23, 2015 03:50 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
Amillionoh7
Aug 7, 2015 01:24 PM
