headers and spark plug clearance
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well, been puttin' around with my engine putting all the nickel-dime stuff on and discovered that the #3, #5, #4, and #6 plugs can't get a spark plug socket on them cuz of the header tubes in the way, so is there a "shorty" socket sold somewhere, or do i need to go with a different type plug now? if so, what kind for a 350 TPI? thanksl...
KAM
KAM
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can make your own or buy one off of ebay for like 8 bucks. I chose the latter since I was lazy. Works wonders.
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
just get a spark plug socket (make sure its the one you can put a wrench on the end of it) and chop the end off with a cutoff wheel or something similar, and make sure you leave about 1/2" of the socket on to grab the plugs edges
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
The socket works great. Joined: Feb 2001
I used a "NON" spark plug socket so the end of the plug would go through hole in the socket meant for the ratchet.
....the socket was completely round on the outside, so I hit it with the grinder and put two flat edges on it.
Car: '91 Z28
Axle/Gears: 323's
good ideas... thanks. i even remembered i had one of those t-handle type sockets and was gonna cut the other end off it, but i'll be dang'd if i can't find it now...
KAM
KAM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
