Cat installed backwards
Old Nov 24, 2004 | 12:51 AM
Mad Morgan's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 Throttle Body
I'm having a ton of trouble passing emissions with my 1988 305 tbi camaro...so I've tuned everything up and fixed just about everything there is to fix. On saturday I went and bought a brand new universal cat for my car. . .and my friend welded it on backwards. I went to take emissions again, and I didn't know it was on the wrong way. I failed even worse, and what I want to know, is the cat ruined from driving about 2 days? I hope if I take it off and switch it around that it'll be ok cause I don't really wanna spend 80 bucks on a new one. Thanks.
Old Nov 24, 2004 | 02:18 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
im not 100% positive on this, but im pretty sure that it wont be hurt by being put in backwards. how do you weld it in backwards.... most universal cats have a huge arrow on them showing the direction of flow, and the air tube should face the front of the vehicle.
Old Nov 24, 2004 | 04:54 AM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
It would help to know what you are failing on the emission tests also.
Old Nov 24, 2004 | 05:30 PM
Mad Morgan's Avatar
First of all, it gets welded in backwards when your friend welding it keeps dropping it on himself, then his girlfriend comes over. I am failing emissions on hydrocarbons.
Old Nov 24, 2004 | 09:16 PM
QuickStyle's Avatar
Car: 91 Z28
Hydrocarbons (HC) (PPM): Hydrocarbons are the component of fuels that produce energy. HC emissions from a vehicle are basically unburned fuel. High levels of HC emissions indicate incomplete fuel combustion, either the result of a misfire or of low engine compression. Unhealthy levels of HC emissions result in a vehicle failing its Smog Check. Hydrocarbons are measured in parts per million (PPM).
check your timing, plugs, wires, coil, entire ignition system, the fuel isnt getting burnt some where, and unburnt fuel will kill a cat really fast.
Old Nov 25, 2004 | 12:46 AM
Mad Morgan's Avatar
I know all that, I've replaced everything that I can basically. I wanted to know if driving it with the cat installed backwards could kill the cat. I'm fixing it asap then going back.
Old Nov 25, 2004 | 02:24 AM
QuickStyle's Avatar
Car: 91 Z28
no it wont kill the cat by installing it backwards, its just a honeycomb type filter, either way the air flows its still gonna do its job, you would just be wasting your money taking it back to smog it with the cat installed the correct way, because it will give the same results, i recommend fixing what ever other problems you have before you take it back and drive around with the new cat on because it will just kill the cat with all that unburnt fuel.
Old Nov 25, 2004 | 12:36 PM
Drakar's Avatar
try a compression test as well on it.
Old Nov 25, 2004 | 09:59 PM
Mad Morgan's Avatar
Well when the new cat was installed backwards, my hydrocarbons went from 1.79 to like 2.83, so something is not right with the cat. If I don't pass this time then I am just getting a waiver for this car and getting rid of it, because I'm sick of it.
Old Nov 26, 2004 | 12:47 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I may be wrong but if you install it backwards doesn’t the air tube face the wrong way? Unless you don’t have the air tube connected at all, that might be your problem all together but we don’t have a sniffer here so I could be wrong.
Old Nov 26, 2004 | 02:30 AM
QuickStyle's Avatar
Car: 91 Z28
did you even try to fix the problem..... if you have a new cat, installed backwards or not, and it still wont pass im about 99% sure that your problem is somewhere else other than the cat. the cat just helps lower the emission, you need to tune your car correctly, just putting a cat on wont fix the issue.
Old Nov 26, 2004 | 02:47 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
How bout this, if you can get the engine running clean enough, can you go and pass smog without a cat, or will you automaticaly fail if you dont have one installed?
Old Nov 26, 2004 | 09:26 AM
Mad Morgan's Avatar
There's no way I'm passing without a cat. The engine runs great, the only thing left for me to do is screw with the timing and I don't have a timing light. I've changed the cap and rotor, spark plugs, plug wires, checked the egr valve, new o2 sensor, put a new cat on it, and other things that I don't remember. At this point I just want to get a waiver so they don't suspend the plates, then just sell it at a low price. I want to get a new car, I'm just sick of this one. It's too slow anyways.
Old Nov 26, 2004 | 04:25 PM
nidyanazo's Avatar
I ment that "in general" sorry.
Old Nov 26, 2004 | 08:32 PM
QuickStyle's Avatar
Car: 91 Z28
timing lights are very cheap, i got my for $20, and having your timing out of spec will cause your emmision to go way up. i recommend either buying a timing light, or find someone to borrow it from, rather than just try to sell it at a low price.
Old Nov 27, 2004 | 11:04 AM
Mad Morgan's Avatar
I've already made my choice for this car. It's past the deadline for emissions and they already suspended my license for it. I'm not going to get much for this car anyway. Someone has hit the fender, the door, the floor pan on the driver side is pretty much gone, no headliner, etc...I'm going to try to sell it for 2 then be done with it.
Old Nov 27, 2004 | 02:55 PM
QuickStyle's Avatar
Car: 91 Z28
im sorry to hear that you are selling it, but the choice is yours. just out of curiosity.... what state do you live in, i have never heard of anyone getting there license suspended for this type of situation, i have an 88 honda crx and it hasnt passed smog for 4 years, it just sits there, but there has been no punishment toward me.
Old Nov 27, 2004 | 05:04 PM
Mad Morgan's Avatar
I'm in illinois. Smog here sucks.
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 22, 2015 07:49 PM
drathaar907
Aug 6, 2015 04:20 PM
