wire protection with headers?
Old Dec 8, 2004 | 08:55 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well, finally got the new engine lit off sunday and almost cooked a couple of wires. namely the temp indicator, fan switch, and main bundle behind the driver head... oh, and a couple of plug wires, even tho i was trying to keep an eye on them... anyhow, what do you guys use to secure and safely route your wires? i put all new loom on them, and the main bundle really just showed signs of the loom getting too warm, but i have to do something i know will work to keep the heat away. i was thinking of re-using my old manifold shields to make something to keep the main bundle away from the #7 tube and use that high temp stuff on the temp and fan switch. it seems to be ok around the heads and block, i'm sure due to those being somewhat cooled. the main bundle is not attached at the trans-to-engine bolts anymore, either - runs behind the heads instead, but pretty much in the same area as before. just did it that way this time so the harness stays out of the way of the firewall wheen lowering the trans.
KAM
Old Dec 8, 2004 | 02:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Biggest problem with plug wires and headers is a the Plug Boot itself.
I solved that by using 90 deg boots and LT1 heat shields. The Shields cost about a $1.75 ea from the dealer, a good investment.
Old Dec 9, 2004 | 06:19 AM
Car: '91 Z28
Axle/Gears: 323's
i have 90* boots on my wires (msd) so good there. are those shields for stock manifolds? i still have mine, but wondered if LT1 shields are different?
KAM
Old Dec 9, 2004 | 08:04 AM
DJP87Z28's Avatar
KAM
The LT1 shields are 90 deg metal shapes for EACH spark plug boot. They are not the manifold cover from the stock exhaust.
Street Lethal
Apr 30, 2019 12:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
