Headers + Sportlines=???
Old Dec 14, 2004 | 08:30 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
What headers shoudl i run with my sportline drop and 17-18 inch rims (figures itd sit a lil higher with 17 or 18 than wit 15s) what everyones reccomendations ive heard hooker long tubes 2055s? are the best but ive heard they dont like dropped cars to well whats your opinions?
Old Dec 14, 2004 | 10:10 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
just stay away from longtubes unless the car is a show car, and i assume u are using the car as a daily driver u will have some pretty banged up headers after this first couple days, just go with the hooker 2055 headers which are shorties.
Old Dec 16, 2004 | 04:19 PM
Car: 87 Formula
Engine: 350 tpi
hmm no other options i really like long tubes but if you reccommend not to ill sat y away from then
Old Dec 16, 2004 | 05:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Long tubes and sportlines would be tough. My I-pipe is awful close to the ground and would be on par with long tube collectors. Shorties will suffice unless your motor really needs them.
Old Dec 16, 2004 | 06:14 PM
Car: 87 Formula
Engine: 350 tpi
450 hp 350 iunno
Old Dec 16, 2004 | 08:34 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
450 hp 350 iunno
You may have one of those situations where you need to sacrifice 10 or so peak HP for the sake of drivability. These cars are a bear to drive when lowered. Now add long tubes and the 4" of clearance you had before just went to 3" or less.
Old Dec 20, 2004 | 12:25 PM
Car: 87 Formula
Engine: 350 tpi
im gonna bring this one back up 3" should be alright my problem is gonna be driving up inclines isint it? as far as just drivin down the road i shoudl be alright correct but as soon as i try and drive up and incline im gonna hit the headers?
theres just soemthing about shortys that i dont like and willing to scrifice driving to certin locals to ahve my long tubes unless you all agree that its a 95%+ bad idea
Old Dec 20, 2004 | 05:17 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you drive on a race track then you are fine. Speed bumps will be the death of you. You can go over them since the car rises as you approach it. However death to your collectors, cat, piping, cutout or whatever you have down there when your front tires go over it and you teedor (sp?) over the bump. I basically turned 3" piping into spintech oval piping by driving over one speed bump. Inclines are rough as well but you can approach them very slow and at an angle as to not dive the nose of the car when braking. It just gets really annoying crawling into driveways and pull ins at 1mph with people behind you honking.
Old Dec 21, 2004 | 10:53 PM
Car: 87 Formula
Engine: 350 tpi
if anyone has this could i see some pics? i saw on the 3rdgen dual exhaust page some pics of pop cans n such sitting under the exhaust to show cleerance tho im sure they were all stock height
Old Dec 22, 2004 | 06:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I do not have long tubes but in this pic you can see how low my 3" exhaust lays. You can see the flange on the cat towards the left there and how close it is to the ground. Now granted this pic was taken in the yard but the clearance on concrete isn't much different. I had just mowed.
Most lone tube collectors will be just as low as the I pipe in this pic.
Old Dec 22, 2004 | 06:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
One more. You can see how low these cars can go even with 26" tall tires and a simple coil spring upgrade.
Old Dec 22, 2004 | 07:08 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Haha yeah I hear that. At my school parking lot I have to just crawl over the speedbumps, whereas the SUVs take 'em at 50 or more.
Oh, and looking at that last pic, you should be careful running your car on the lawn. You wouldnt want to burn or set fire to your freshly mowed grass, would you?
Old Dec 22, 2004 | 08:59 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I don't live their anymore. I think my 30 year old craftsman lawn mower did more damage than the car ever did.
Old Dec 22, 2004 | 10:48 PM
Car: 87 Formula
Engine: 350 tpi
ok thansk alot for the pics im still deciding weather its worth it or not signs are pointgin to no but any more pics would be apperciated
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Chiknhawk
Sep 10, 2015 08:55 AM
