High Flow Cats
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
High Flow Cats
I have a Dynomax Exhaust....pretty big 3 inch pipe (on a V6)
Would a high flow cat make a big difference in sound and power?
Since the out pipe is 3 inch does that mean I need the all around 3 inch cat?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what sensors? only one i think of is the o2, and it may be a little off by disconnecting the cat, but not by adding a high flow.
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i dont see why it would make your sensors go haye wire because i am running no cat and my sensors are fine.
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
removing the cats from our third gens does not trip any sensors, nor does having a high flow cat. unless of course you did an engine swap with obd2 compliant f.i. system. i have a dynomax high flow on my car, don't know if it made it any louder because i installed it with my BLOWMASTER exhaust.
Transmission: 4L80E/4L80E
Apparently, the reduced back pressure (yes, that's what I said) can have a negative effect on a positive pressure type EGR valve. If that particular model has a monitor for EGR function, a code can be set because the EGR isn't opening properly. The fix is to replace the EGR valve with a negative pressure type (i.e., "normal" aftermarket) valve. Doesn't happen everytime, but has been reported.
