QTEC vs McCord
Old Jan 7, 2005 | 11:17 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
QTEC vs McCord
Been doin a lot of searching, I just want to get a few things strieght on these two electric exhaust cutouts.
The QTP is $190 and the McCord is $110 w/ a warentee.
Here is my question, is the McCord just a powerplate that you have to physically put on to a regular cuttout that you would purchase separatly?
http://www.quicktimeperformance.com/...uct_detail&p=3
http://www.mccordcg.com/mpp/mpp.htm
Which would you go with, Im runnin Edelbrock 3in TES headers and I want the cutout before the Cat. I dont care about the price difference.
Old Jan 7, 2005 | 11:20 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Well 110 + 35 from summit = 145, but you dont care.
I would go with the mccord. mmm...warranty...
Plus, the Mccord has a LED and other stuff. With all the advancements they have made, I really believe it is the better of the two. Want proof of my sentiments? I just bought a Mccord.
Old Jan 7, 2005 | 11:21 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
whats the +35 from summit?
is that the price for the exhaust cutout that the power plate bolts onto?
Old Jan 7, 2005 | 11:25 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah.
edit: oops, my bad. 26, not 35. I think mine came out to 35 Canadian. And I got a $15USD gift certificate from them with the purchase
http://store.summitracing.com/partde...4920534+301655
Old Jan 7, 2005 | 11:27 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
will any 3in exhaust cut out work, or is there a certain shape or kind I should get.
So basically how this is going to work is a regular 3-wing nut cut out is going to have an electric cutout instead of the wingnut cover?
Old Jan 7, 2005 | 11:30 PM
305q_ta86's Avatar
Transmission: 5 spd
Yup pretty much. When you buy it, you specify that you are using a cutout (it will say flowtech, jegs, etc, but the summit one works too. I tried it on mine already.) and then they will machine special reliefs into where the bolts go so that the nuts will tighten properly.
Like this:
Old Jan 7, 2005 | 11:35 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
as far as wiring one of these bad boys in, is it hard? I read the install instructions, but where would i find a "hot" 12v ignition wire to splice this into?
Old Jan 7, 2005 | 11:45 PM
305q_ta86's Avatar
Transmission: 5 spd
I asked Trickster about it. You can tap into junction c236, IIRC, which is behind the driver side kickpanel. Alternately, you can tap into the fustbox (do a search for my name and you will find the thread) or, you can do what I will probably do: tap into the orange wire leading to the cigarette lighter and use that. This is not a switched source, however, so you would want to also install a toggle switch. I will probably do this for a while, and then switch to the junction Trickster told me about a little later down the road...
Only thing I havent quite figured out yet is how to get the wire from the cutout to the switch in my automatic, but I see you have a standard so you will probably be able to run it through the lower shifter boot, whereas I will likely have to runit up and through the hole in the psgr fender where all of the wiring goes form the engine to the computer. (for me that is, USED to go. )
Btw you need a power, ground, and then just run the wire to cutout and you're done.
Old Jan 7, 2005 | 11:57 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
it's very easy to install....just hooked up to a power source and a ground. I hooked mine into the fuse box...which was very easy. Also, I had to take some of my carpet up and run my wires though the floorboards...very easy installation. I've had McCord going on 2 years now with no problems...I love it
Old Jan 8, 2005 | 10:45 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
when you run it throught the fuse box, its not "hot" its accessory right, but it rele dosent make a difference... just that you could also move the motor when the key is turned to accessory, right? Cause that seems alot easier than tapping into ignition wires.
Old Jan 8, 2005 | 10:51 AM
Engine: 5.7
I mine hooked to a fuse that only alows me to operate the McCord in the "On" position. Here is my McCord and Cutout:
I'll post a picture of my switch panel in just a few
Old Jan 8, 2005 | 10:53 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
ok, thanks... do you have yours b4 the cat?
also would you reccomend getting the exhaust cuttout heat treated b4 you install it?
Old Jan 8, 2005 | 11:53 AM
Engine: 5.7
Well, I removed both of my CAT'S...so..it didn't really matter. You might try a search..because some people put them before..and some put them after. Heat treated....meaning like a JET HOT coating? It wouldn't hurt...I didn't coat mine...but it's fine.
Here are a few pictures of my switch panel:
Old Jan 8, 2005 | 04:12 PM
305q_ta86's Avatar
Transmission: 5 spd
Well here's how I set mine up.. JUST finished doing this, too. Not fifteen minutes ago. I have the rockerswitch between the pwr window switches, and then that toggle switch where the cigarette lighter used to be is the main power switch, because it is tapped into the cigarette lighter wire, which is always hot.
Oh and ignore that other switch by the rockerswitch, that's just for the antenna.
Old Feb 20, 2005 | 04:31 AM
DaBlackTransAm's Avatar
Car: 85 trans am
Engine: 350 vortec
Transmission: turbo 350
nice that pretty nice idea.
i was going with a qtec till i read this. mccord seems be better buy.
Old Feb 20, 2005 | 09:32 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
just bought my mccord powerplate yesterday and the summit cuttout, cant wait for it!
Old Feb 20, 2005 | 09:34 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
my camaro is completly base, i have no power windows, hatch release, seat motor, door locks, etc. My question is, is my fuse box the same as a car that does have all thes options, in case i wanted to tap into them for something like my electric cutout?
also what kind of connector do i get to tap into the fues box (one from a store not a scrap yard) and how do i know what spot on my fuse box to tap into?
Old Feb 21, 2005 | 12:58 AM
305q_ta86's Avatar
Transmission: 5 spd
Trickster told me to tap junction c236, behind the left kickpanel.
I tapped the ciragetter lighter wire instead. :S
Old Feb 21, 2005 | 11:38 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
i have no idea what/where junction c236 is, and i dont want to tap into something if i dont know what it is, so can i use any of the spaces on my fues box?
Old Feb 21, 2005 | 12:04 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah you can use the one in the lower left called "IGN". It's only hot when the key is on.
Sorry for it being blurry. This is a 'file photo' I took a while ago. See on the lower left there, the two labelled IGN?
Old Feb 21, 2005 | 12:19 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
ok, but they dont look big enought to insert a regular sized fuse, so how do u get the wire in there, also do you insert the power and ground in the fuse box, or you ground it separatly on the chassis?
Old Feb 21, 2005 | 12:43 PM
305q_ta86's Avatar
Transmission: 5 spd
I would ground it seperately. And you dont need to stick a fuse in there, the mccord comes with an inline one already.
Old Feb 21, 2005 | 12:54 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
so the wire will just slip into that hole... but how do i stop it from falling out?
Old Feb 21, 2005 | 02:54 PM
305q_ta86's Avatar
Transmission: 5 spd
I dont know. I tried to get at it from the back, but I decided to instead be lazy and just tap the cigarette lighter wire. 3 months, no problems.
Old Feb 21, 2005 | 03:19 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
you also said that you had some kind of toggel switch at the cigarett lighter, what was purpose of that and can i have a pic of that?
Old Feb 21, 2005 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have dual mccords, and couldnt be happier with them...
Old May 1, 2005 | 06:59 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
i just installed the power plate today, i didnt tapp into the fuse box or cigarette ligher, i just ran a new line to the battery and connected it to a relay switched by the ignition... so it only works when the car is on.
the plate is fully functional, and i am going to have the cuttout welded in tommorow, I will post pics soon.
toxik IROC
Feb 26, 2008 11:06 PM
OUTATIME GTA
Jun 20, 2006 12:59 AM
NatesL98
May 31, 2004 04:11 PM
TransAm12sec
Feb 23, 2004 03:32 PM
MetalliCamaroRS
Feb 15, 2003 10:34 AM
