Exhaust leak from header....difficult to do?
Old Jan 11, 2005 | 01:32 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I still don't have a jack or jackstands, but I know it is coming from the header...it is annoying and I get high off the fumes... HELP
Old Jan 11, 2005 | 01:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
tighten the bolts, duh.
:lala:
Old Jan 12, 2005 | 12:51 PM
Project's Avatar
Car: 85 Camaro Z28
Okay I spent 80 bucks on jackstands, 2 1/2 ton jack, and a jeepers creeper JEEPERS CREEPERS WHERE DID YOU GET THOSE PEEPERS...WERE DID YOU GET THOSE EYES?
I tightened and it is still there, it is without a doubt the headers I can see condensation (sp)
Old Jan 12, 2005 | 12:55 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If you're seeing it up at the heads. you may just have to replace the exhaust gaskets. I had one start leaking on a road trip and before I could get it tightened up it had burned the gasket. Only choice at that point was to replace the gasket. Wouldn't seal otherwise....
Sorry to be the bearer of bad news, I know that's no fun. Hopefully your problem is on the driver's side since it's a little easier to get to (wouldn't be with my luck though....)
Old Jan 12, 2005 | 01:14 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If you have cheaper headers and paperboard-type gaskets get used to this. You probably will develop the skill of doing this by yourself, espically if you're friends have camaros and headers like yourself
Old Jan 12, 2005 | 02:25 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Yea, don't skimp on the header gaskets.... it's worth it to get the good ones. Seems like people have good success with the deadsoft aluminum or copper ones. I had some very good ones - the Earl's with the graphite inserts, but they can be hard to work with because on mine, the inserts kept falling out when I was trying to put them on, but once you get them on, I don't think they will ever blow out. I would also highly recommend the stage 8 locking header bolts. They will keep the bolts from backing out and loosening up, which leads to the gaskets blowing out. Unfortunately, I dropped two of my clips and they got lost in the frame somewhere so I have a couple that I'll need to check regularly.
Old Jan 12, 2005 | 03:06 PM
vernw's Avatar
I'm using the Percy's Dead Soft multi-layer aluminum gaskets (not cheap by any means) and the headers are SLP Tri-Y's. Not cheapies either. The bolts are cheapies - I had to go with hardware store allen head bolts to get them in and be able to tighten them up w/o pulling the motor. WIsh I could handle a locking style bolt a couple of hours so I could see if they would even fit. Maybe I can find some locally and check them out....
Old Jan 13, 2005 | 02:23 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
mine didnt come with exhaust manifold gaskets?
Old Jan 13, 2005 | 02:27 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
solution: get the gaskets.
another "" for good measure.
Old Jan 13, 2005 | 04:05 PM
Car: 91 Camaro RS
Ditto. You bought some right?
Old Jan 13, 2005 | 11:15 PM
theMachinist's Avatar
Car: It was a 90' firebird formula
Engine: It had 357 tbi
Transmission: Was 700r4 auto
Axle/Gears: Was 2.73
i hate to diss on the gaskets, but i'v learned from a couple of engine machinists, one guy a dragster and has never had a leak, but if u have the headers service smoothed so there perfectly flat, u shouldnt have to worry bout the headers ever leaking,
Old Jan 14, 2005 | 08:08 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
deadsoft aluminum gaskets will stop the leaks unless the headers are warped beyond repair.
Old Jan 17, 2005 | 12:31 AM
sickstrings84's Avatar
Car: 2003 Chevy Cavalier LS
Engine: 2.2 I4 ECOTEC, crane cam, FAST piggyback ECU
Transmission: 5 spd
Re: Exhaust leak from header....difficult to do?
Originally posted by Project
I still don't have a jack or jackstands, but I know it is coming from the header...it is annoying<i> and I get high off the fumes...<i> HELP
Hell man sounds good to me. Roll around in a thirdgen and get high.
Tim:rockon:
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
