Making exhaust more. Quiet..
Old Feb 8, 2005 | 06:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I know this is taboo among most folks, but i've never really been into noise.
My last setup was just out right obnoxious.
Anyone have any hints or suggestions on making my car a little less noisy, without losing too much power? (more than 5-8hp).
-- Joe
Old Feb 8, 2005 | 08:44 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
It's been suggested in previous posts trying those header inserts from Jegs and Summit. Suppsedly you put them in the collector and it will lower your db's without sacraficing hp. Does it work? Who knows, nobody ever posts back when asked about this but it's worth a shot. Does it work with shorties? Not sure but it could be looked into.
If your not running a cat, possibly putting a high flow unit will lower your noise level a little.
Hope that helps.
Old Feb 8, 2005 | 09:09 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Or you can do what I did, and run a cutout before the stock muffler.
Old Feb 8, 2005 | 10:09 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
But I don't live in a trailer park..
-- Joe
Old Feb 8, 2005 | 10:10 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hope that helps.
I'm running a cat. But its still too damn loud..
I'll lookinto the inserts.
Any other ideas?
-- Joe
Old Feb 8, 2005 | 10:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
-- Joe
perhaps you're not catching on.
when is the ONLY time the performance diff of a stock muffler vs any other muffler measurable?
at the track.
if you want a real liveable setup, do what alot of guys do..
run a stock exhaust, and get a electric cutout.
when you want to be loud, its loud.. and depending on where you put it, your motor, ect... it doesnt sound bad.
when you want it to be quiet, you just flip the switch and the cutout closes.
i only open mine at the track... athough occasionaly i'll open it to scare the **** out of some ***** who just reved at me... (i wont run him on the street, but its fun none the less....)
before you dismiss it as ******* trailer trash, do some research on the subject... you wont come off as ignorant that way
some to get you started:
http://www.mccordcg.com/mpp/mpp.htm
http://www.quicktimeperformance.com/QTEC/
www.ls1tech.com (do a search here on the above cutouts)
Old Feb 8, 2005 | 10:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw the inserts are there for race cars that need "mufflers" to be legal.
they wont make your car any quieter.
Old Feb 8, 2005 | 03:25 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
You could try putting a resonator in your exhaust system right behind the cat where the pipe it fairly straight. I would think that would bring the sound level downj a bit.
Old Feb 8, 2005 | 04:52 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Get the biggest magnaflow you can fit on there. Do NOT use the collecter inserts. I've seen some guys on another board use various ones.... on a pretty stout 350 it'd barely accelerate, and on another the exhaust flow bent the fins on it!
Old Feb 8, 2005 | 09:19 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
at the track.
I can't use cut-outs at the track. DOT approved mufflers for all entries..
Thanks. I'll keep looking around.
-- Joe
Old Feb 8, 2005 | 09:28 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
-- Joe
Oh snap!!!
Old Feb 8, 2005 | 10:35 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
I would put a Dynomax Bullet between the Cat and muffler somewhere.
Old Feb 8, 2005 | 10:42 PM
anondude13's Avatar
I second that. Another small muffler or resonator will help.
Old Feb 9, 2005 | 08:48 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
-- Joe
ok
another option, i have a friend that does this.
put a stock muffler on. (i reccomend the later 4thgen Z28 ones)
put a flange on where the I-pipe goes into the muffler.
at the track, you can drop the heavy muffler and bolt on a bullet (or somthing of that nature)
lil more work, but you also get the weight loss...
Old Feb 9, 2005 | 10:14 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
I just put a Flowmaster Super 40 on my GTA. Not loud but still makes good tone.
Old Feb 11, 2005 | 09:59 PM
onebinky's Avatar
Anesthes is probably pushing a good amount more power than you though
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
midias
Aug 15, 2015 05:07 PM
