Borla...?
Car: 91 Camaro RS
Engine: 305 TBI w/ MSD ignition
Transmission: 700 R4 (stock)
Borla...?
anyone have Borla exhaust on their camaro 305 pr LT1?? does it sound really throaty like on the corvette or is the magnaflow etc. better for sound and or performance??
Car: 1987 IROC-Z
Engine: L-98 350 TPI
I am wondering the same thing. I am thinking about buying it for my 87 iroc. Not sure if i should get a 93-01 system or get the one made for my car and change thoes tips to the bora intercooled tips or polished z28 tips.
Engine: 305 5.0L F engine code
I have the borla on my 305. It fits like crap. The left side of the muffler is 1.5 inches lower than the right side.
Also, it does not bolt up the the cat. I thought that it did, I guess it was suppose to bolt on to the y-pipe. But it does sound pretty good if you do not use any of the restricting plates.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Borla
A five letter word for junk IMO!
Ihave had the same results as the other guy, bad fit.
Car: '91 Z28
Engine: LB9
Seems that there are some diffs in production quality. Mine fitted with no problem, my friend had some little problems but nothing to worry about
Sound I also a bit different. Mine is much louder due to the dual cat.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i couldnt be happier , i will include some pics, fit great
