anyone ever remove the air tubes?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
since i no longer need to smog the car EVER, is it possible to cut the airtubes from my nice edelbrock ceramic headers? how would it be done, and maybe would a shop in california be up to the task?
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
the only real important thing is that you remove the air pump from the serpentine belt path. Beyond that, people tend to just cut off the air tubes and weld the holes left shut. Lots of people can do this on their own and it looks seamless almost. For some reason i want to say 25thrss did a very nice job but my memory is bad and i could easially be wrong. Run a search and you should come up with all kinds of info on dumping the air tubes.
-chillen
-chillen
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I'd just get new headers w/o air tubes and then delete the pump and hoses. Then sell off the headers w air and be done with it.
My .02
Laters,
Conrad
My .02
Laters,
Conrad
Transmission: 4L80E/4L80E
There's a sticky about the ill-advisedness of running TPI w/o A.I.R.
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
i have edelbrock TES headers that originally had the air tubes, and i just cut them off with a cutting wheel, crimped them with vise-grips and welded a small bead to close it off air-tight. have had no problems with it yet.
Car: '02 Z06
Engine: L33 5.7
but hows it look? i want a nice looking engine bay.
i have taken into account about the bad idea of removing the air tubes cuz of the o2 variable.. but i can live with that for the time being till i get a chip burned.
Car: 84 camaro
Engine: 1979 305
Transmission: 700
a buddy of mine gave me the manifolds from his car when he got headers.. my carbed 305 doesnt need smog, so what i did was i took the pipes off the top and used pipe plugs in the holes. I could have cut some threads off so they fit flush, but i dont mind the "frankenstein" look. i also plugged the O2 sensor i could take a pic if you wanna see what stock ones look like with plugs.
It's not real hard, just time consuming. First, cut off the air tubes close to the headers, then grind down the remaining bit of air tube to ensure the weld will fill the hole completely. Next weld it or take it somewhere to have the holes welded shut. If they ask why, tell them it's for a "race car."
After the holes have been welded shut take a die grinder and smooth the inside and outside of the weld down until you are happy with the results. It should turn out similar to the pic above. Good luck.
After the holes have been welded shut take a die grinder and smooth the inside and outside of the weld down until you are happy with the results. It should turn out similar to the pic above. Good luck. I have done it. but mine is a carbed 84. i broke them off as said and unscrewed the fittings. The went to the local parts store and spent 6 bux on closed fittings and 'tape' and screwed them back in worked like a charm!!
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Re: anyone ever remove the air tubes?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Re: anyone ever remove the air tubes?
Originally posted by pasky
I did it to my SLP's last week. Just chopped them off with a dremel and a cut off wheel. I bought some cold weld (JB Stik). Kneaded some in my hand and shove it into the air tubes holes. I'll let you know if they hold up to the heat, if not im just gonna weld some metal.
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Trash the junk, too many run without any smog without any problems whatsoever on a stock chip.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why take it off just because you dont have to pass emitions? Its not hurting anything by being there, and removing it just might cause problems with TPI.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My car came with it already removed. The previous owner cut the hoses and squeezed them shut with pliers/vice grips. I haven't had a problem so far.
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 13, 2015 08:28 PM
