Is this Mac Header System any Good?
http://www.hawksthirdgenparts.com/in...?v=1&pid=15568
I was looking into something that includes a new y-pipe and this showed up, is there a better system out there that is around the same price and is this the cheapest place to acquire this system?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i've heard really good things about them, and almost bought them myself, but i decided to go longtubes/true duals instead. it appears that that is the cheapest place to get them. the hooker 2055's are a bit cheaper if you get them uncoated, and i have heard really good things about the hookers. most folks want them coated though. the mac's are not ceramic coated, however, but have some kinda high-temp paint of some sort on there. i don't know how well they hold up appearance wise though.
Axle/Gears: 9-bolt/3.45
I've never read anyone here say they're using the MAC header system, but I've read a few say they're interested in it. I too think it looks like a good system, and it can be had with or without AIR. I'm considering it eventually, and the Y-pipe is a big part of my decision.
I currently run the MAC stock-replacement Y-pipe. It's excellent--a little larger and much better than the stock Y-pipe. It's solid, one-piece and mandrel-bent--very nicely made! The Y-pipe included with the headers is similar. After seeing the MAC Y-pipes, it's my opinion that they're are probably the BEST available.
The silver "HTS" paint coating doesn't seem like anything special though, but it's held-up well and looks good. But I'd think you could send the headers out to be thermal-coated, if that's what you wanted to do.
I plan to use the 3" MAC Y-pipe with the SLP 1 and 3/4ths shorties. I agree the MAC Y-pipes are great. I got the Y-pipe here in my garage, and the SLP's on another car (need to remove them). I have not decided on the rest of the exhaust system yet, but this will be going on a vortech blown L98 with a HSR and a blower cam.
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I actually asked this same question on my car club site, afbforums.com. Quote taken from Benny:
" I've had a set on my 92 RS for about 2 years, they fit/sound/work great. Plug access is good. The y-pipe interfered with my old style boxed Spohn subframes, but a dremel and air grinder took care of that. The coating sucks though, they looked good for the first 6 months to a year, but when I pulled them a few weeks ago they were kind of rusty. However, I've only started the car 3-4 times over the past year so that might have had some effect. dunno.gif As for installation, I had the engine out of the car when I installed mine, but with the headers mounted on the engine, it dropped right into the car with plenty of clearance. When I pulled the headers though, I only removed the spark plugs, AIR solenoid box and unbolted the valve covers, then they both came out the top fairly easily."
