Long tube headers w/o pulling engine?
Old Mar 13, 2005 | 03:12 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Are there any long tube headers out there that are easy to install without pulling the engine part way out. I here they can do a pain to install. Do the long tubes give you much better horsepower or sound better than shorties?
Old Mar 13, 2005 | 05:00 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
i'll let you know in a couple hours
i'm guessing i'm just gonna have to unbolt the mounts and jack the engine up one side at a time, my LT's look like they will fit with just an inch more of clearance. they hit the bellhousing right now...
maybe i'll snap pics
Old Mar 13, 2005 | 08:32 PM
trueburton's Avatar
thanks i'm looking into getting headers but i want some log tubes that will go in easily.
Old Mar 13, 2005 | 10:34 PM
Engine: 450HP 355
Transmission: TH350
well, due to the lovely warm 35F it was outside i only got my collectors unbolted form the shorties, it's supposed to warm up a bit this week so i'll be working on it off and on..
Old Mar 14, 2005 | 01:15 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
pass. side from the top, driver side from the bottom, hedman longtubes. didn't even have to jack the motor up.
Old Mar 14, 2005 | 09:20 AM
trueburton's Avatar
thanks i'll keep those in mind. Remember what you paid for them?
Old Mar 14, 2005 | 10:18 AM
mw66nova's Avatar
Engine: 7.0L
around $120 from jegs.
Old Mar 14, 2005 | 12:20 PM
trueburton's Avatar
wow that seems really cheap. What size tubes and outlet?
Old Mar 14, 2005 | 02:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1 5/8" primaries, 3" collectors.
Old Mar 14, 2005 | 03:23 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i had my hooker long tubes in in about 2 hours puttin them in last yr, and then a few weeks ago i had them and the entire exuast system off in about 2 hours. so it only took about 45min to an hour to take them out. i put them in and took them out thru the bottem. didnt have to jack up the motor. the only thin i think ill do if i ever put longtubes on another 3rd gen is make sure to take the oil filter off. little ibt of a pain on the driver side with the oil filter on.
Old Mar 14, 2005 | 03:43 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
also,
try to go from under the car .. i know it sounds dumb but alot of people never try it when installing headers but give it a try before u jack up the motors. well thast my
Old Mar 14, 2005 | 07:49 PM
trueburton's Avatar
I looked on jges for those headers and found some for 139.99 and the picture is of long tube headers but when i click on more info it says they are shorties and something about modifying the A/C bracket? Are these the ones you were talking about and what modification of the A/C bracket is required?
Old Mar 14, 2005 | 08:26 PM
mw66nova's Avatar
Engine: 7.0L
hedman p/n 68460 for the longtubes.
and they are now priced at $135.99, when i bought my first set, they were $109. the second set i got at $119.99
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
