Worth it to coat y-pipe?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I can get a hedman y from summit for 98.99, but coated from jethot it is 227.00. Just wondering if it is worth 127 bucks to coat this piece. thanks guys
Will
Will
Car: 92 Z28
Engine: Boosted LSX
Deff. worth it. How long is the Y pipe? I might be able to beat jet hots price for you.
Just a example of some work I have done
http://www.cecoatings.com/images/coa...Of%20Parts.jpg
Car: 92 Z28
Engine: Boosted LSX
I prefer they get sent in right off the car etc. I prefer to do the prep myself. Kinda like if you take a pre preped car to get painted. You Know a good painter is picky and rather do the body work himself.
Same goes with coatings. Someone might think "Mmm, I'll blast em with Aluminumoxide to get all that rust off." Bad idea. Its to rough and actually dimples headers.
These look bad in person.
Transmission: A4
Do the benifiets out weigh the cost to have this done? I mean, to have a set of headers AND y pipe done you proberbly looking at $200-$250. Thats a lot of money to spen on something like that.
Car: 85 Trans Am
Engine: 305 Carb
I would have to say it is worth it to have the parts coated. Yes, it is a bit expensive, but with the coating the parts will last a lot longer than if un-coated, or just painted. Especially if the car is driven a lot. With coaters like TPI383 offering a lifetime guarantee on coatings on new parts, that says something about how long the part is likely to last once it is coated.
Compare it to the cost of replacing uncoated pipes(don't forget the labor) when they rust through, then it might not seem quite so expensive. Then there is the appearance factor, ceramic coated looks so much better than old rusty header pipes.
Transmission: A4
well, I have a set of coated SLP headers and to tell you the truth, they dont look to good anymore. sometimes Iwonder if SLP would ever redo them for me but then I remember that its SLP.My headers are the first things that I have owned that have a coating on them and the results dont look good now so Im concerned about spending money on this process
Car: 85 Trans Am
Engine: 305 Carb
From everything that I have heard/read about the factory coatings, they are just not up to par with aftermarket coaters. Case in point, I have a friend that had a set of edelbrock coated headers on his Monte SS, and the coating starting coming off after a few years, and it was only driven in good weather. Not familiar with SLP's coatings though, maybe someone else here is.
I have seen users on these boards talk about aftermarket coatings that still look almost as good as new a few years later. I spent a lot of time reading/researching the topic before I got my coated headers/ypipe. The extra cost was a big concern for me as well, but in the end I decided to go the extra cost now for both the longevity and looks. Only time will tell for sure if it was the right choice.
skinny z
Oct 5, 2015 06:23 PM
