Header bolt help!!
Old Mar 19, 2005 | 06:00 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Header bolt help!!
Okay so i blew a header gasket on the passanger side. The problem is i attempted to replace it and got everything in but the bolt closest to the fire wall. Now the gasket is bad, i need to replace it again. My question is how did you guys get to that bolt? btw i have hooker 2055's.
Old Mar 19, 2005 | 06:26 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I am guessing that it's the one on the passenger side. It's a pain and you will need to find the smallest length wrench to fit in the confined space. I had to remove the emission items out of the way to get a better handle on the bolt.
Old Mar 19, 2005 | 06:27 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i had the same problem bro. what i did was take all the bolts off again and start from the back fowards. belive me!!! it really works.
Old Mar 19, 2005 | 06:31 PM
phoenix305's Avatar
Thanks guys i even took it to an exhaust shop and they told me they wouldn't.
Old Mar 19, 2005 | 11:03 PM
83 Crossfire TA's Avatar
Get a cheap wrench and cut it in half. I also ground the sides of mine down making it narrower so you can get more of a rotation before you hit the header tube with the side of the wrench, and keep it in the toolbox as my “header wrench”
Old Mar 19, 2005 | 11:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Thats what I did. That combined with my skinny arm worked wonderfully.
Old Mar 20, 2005 | 12:58 AM
86z/92rs's Avatar
You probably have done it already but for those that are new and looking to become shade tree mechanics, I would suggest disconnecting the battery cable. Last thing you need is a fire when you drop your tool on the starter when you are removing or installing headers, spark plugs or just general work around the engine.
Old Mar 20, 2005 | 01:22 AM
91Z28-350's Avatar
Go from underneath. Drop the Y-pipe to that side, and the starter. Use a crow's foot and a ratchet.
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
